Author Topic: Ian Tyrrell fabulous You Tube Video on the Pagoda  (Read 622 times)
Drewtee
  • England, Kent, Sevenoaks
« on: August 21, 2025, 08:36:55 »
I did a search to see if this has already been listed here but couldn't find it- Apologies if it has been. I'm sure many of you have already seen it.
 A nice interesting video of the Quirks and Quality of the Pagoda
<iframe width="560" height="315" src="https://www.youtube.com/embed/EW1UIMlESLk?si=9TxPeJW3FzA6u2QY" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
https://youtu.be/EW1UIMlESLk?si=qJkNgvL4Xmw89KDJ
Andy Tee
Rhd 5 speed 728h with parchment interior
LHD Brabus - 4 speed , soon to be 5 speed.
W111 3.5 Cab and Coupe both RHD
Re: Ian Tyrrell fabulous You Tube Video on the Pagoda
« Reply #1 on: August 21, 2025, 09:22:01 »
He knows about as much as any typical long term owner. He needs to study how the timing chain works - it's not oil pressure fed or ratchet activated. That system came on later cars like the 280 twin cam.
« Reply #2 on: August 21, 2025, 10:46:27 »
Nice video, thank you for sharing!
I think 190SLs had the same door set up - full aluminium frame and aluminum skin…. Or am I wrong here?
By the way: when I get to valve clearances adjustment I always turn the engine a couple of times with the starter (with ignition off) to see if oil is dripping through all of the small holes in the oiling pipe.
« Last Edit: August 21, 2025, 10:59:35 by Pawel66 »
« Reply #3 on: August 21, 2025, 15:54:54 »
I watched it when it came out and made a comment to Mr Tyrrell's claim that the Pagoda is the only car he knew to have all aluminum doors. Because my 1973 Lancia Fulvia also had all aluminum doors. But his is a generally enjoyable channel.
Jordan
  • Canada, ON, Jordan
« Reply #4 on: August 21, 2025, 16:41:27 »
Yes, the early Fulvias also had aluminum doors, hood and trunk lid, the same as the Pagoda.  While not really cars, the Land Rover Defenders also had aluminum doors.  All the body panels were in fact aluminum, not just the doors, until 2007 when Ford took over and they went to steel.
Marcus
66 230SL  Euro 4 speed
Drewtee
« Reply #5 on: August 22, 2025, 09:34:07 »
I'm amazed he has managed to get this incorrect - He is supposed to restore them!  ::)
Andy Tee
« Reply #6 on: August 22, 2025, 20:24:05 »
That timing chain was very loose which means all of the gears are worn out plus the chain . This is basic 101 stuff that he should know about.
Sorry, not that impressed.
