Author Topic: 280SL Suddenly won't start  (Read 55 times)
johnshenry
  • USA, NH, Northwood
« on: Today at 15:45:14 »
Our '69 280SL has been running flawlessly for a few years after a new engine rebuild.  Yesterday went to take it to the golf course and it wouldn't start.  A loud click and a whining sound (fuel pump I presume) when I turn the key to the start position.
Put a charger on it over night, went to try it today, same thing.  Put a meter on the battery is was 12.47 volts, and around 12.1 when I turned the key to start so I presume the battery isn't the issue.
Oddly, the taillights and reverse lights come on when I turn the key to the start position, and, I found that I can push/roll the car when it is in D, R or P (?).
Been a gearhead for 40+ years, and have several other antique rides, but confess I don't wrench on this one much (I write checks).  Ideas/tips on what to check next?
Vander
  • USA, OH, Columbus
Re: 280SL Suddenly won't start
« Reply #1 on: Today at 16:08:59 »
If you can roll the car in any gear it sounds like your shifter linkage bushings broke underneath the car.
They are on the side of the transmission, and can be seen easily if you have a way to jack it up and get underneath.
Car won't start because the transmission is not in park, even though the shifter inside appears it is. Neutral safety switch is doing its job.
johnshenry
« Reply #2 on: Today at 16:41:56 »
That makes sense given the symptoms.  I'll get under there and have a look.  Thanks......
« Reply #3 on: Today at 20:53:33 »
These bushings are a common problem.  Use our Search feature on this forum and learn all you need to know.
