Author Topic: fuel pump volume at return vs outlet  (Read 354 times)
ryanpe56
  • USA, CO, Eagle
« on: July 24, 2025, 17:34:34 »
'71 280 SL with rebuilt fuel pump I have 1.3L in 15 sec at the outlet and .56L in 15 sec at the return line. Is this sufficient? I'm trying to solve a 4500 rpm max rev issue. Is the return line compensator adjustable? Is the goal to have 1.5L at the return as well as the outllet?
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
Re: fuel pump volume at return vs outlet
« Reply #1 on: July 24, 2025, 18:04:30 »
Should be 1l per 15 seconds at the return.  Check the lines first
Lori
1968 280SL (US)
ctaylor738
  • USA, VA, Falls Church
« Reply #2 on: Today at 15:37:03 »
A flow of .6L / 15 seconds is not ideal but I don't think it would cause your RPM limiting.  I agree with Joe, most likely a bad coil unable to refresh fast enough.
The return flow is not adjustable. There is a spring-loaded pressure valve in the pump's exit, and a diaphragm in the modulator.
The test on the input side is 1.1 to 1.3 bars of pressure measured at the cold start valve.  I undo the line and connect a gauge by pushing a 5/16" fuel line over the line's fitting and securing it with a hose clamp.  The line attaches to a pressure gauge.
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
