Author Topic: Interesting features in this '67 230SL on Car Wizard  (Read 4079 times)
Jack the Knife
  • USA, FL, Vero Beach
« on: May 12, 2025, 01:16:03 »
https://www.youtube.com/watch?v=RNHl7o1tmwQ
The coco mats at 5:58 are identical to the ones that were originally sold with my car and are reflected on my car's build sheet. They were also in tatters, but I can more clearly see the pattern and style in this car.
Very interesting aluminum(?) fan at 9:10, compared to my plastic or whatever it is fan on my "'64" (build date was Feb. '65).
1964 230SL "Blue Note" -- #009785
2015 G550 "Milk Truck"
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
Re: Interesting features in this '67 230SL on Car Wizard
« Reply #1 on: May 12, 2025, 11:57:31 »
I have the aluminum alloy type of fan on my German spec 1970 280SL.
Robert Hyatt
Williamsburg, VA.
MikeSimon
  • USA, OH, North Royalton
« Reply #2 on: May 13, 2025, 23:21:33 »
Maybe MB installed whatever they had that day in the parts bin? My German spec 280SL built in November 1970 has a plastic fan.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Duncan200
  • 05-02-25 Just finished my Restoration
« Reply #3 on: May 14, 2025, 00:38:19 »
I too can vouch for MB fitting whatever they had available, given my late 66 230 has a long stroke crank and 250 rods fitted to it.
1966 MB 230SL DB 717 4sp Australian Delivered Matching Numbers Car. One day has come and she is back on the road
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
« Reply #4 on: June 07, 2025, 19:01:35 »
Since this is the "originality" forum, I'll ask you, Duncan200, how do you know that those parts were installed at the factory?  🏭
« Reply #5 on: June 08, 2025, 04:19:08 »
You can fit a 230SL head on to a 250SL block. Just saying.
« Reply #6 on: June 09, 2025, 03:45:16 »
Hi Dan,
Yes, that's true.  This forum is about factory originality, and Duncan200 seems to believe that the factory put a long stroke crankshaft and 250SL piston rods in his 230SL.  That's what I'm questioning.
« Reply #7 on: June 09, 2025, 03:55:08 »
Hi Dan,
Yes, and the answer is a 250 block.
Duncan200
« Reply #8 on: June 09, 2025, 10:35:46 »
Gee Rod if I knew you were going to be like a dog with a bone, I wouldn’t have mentioned it.
I was merely going of what my engine builder said whilst he was rebuilding my engine and it appears the rods available from Niemoller for the later 230’s also fit in a 250. He also said he was fairly confident no one had been in there before, but I’m going off of his opinion.
Happy to delete the post if it upsets anyone.
Doug
« Reply #9 on: June 10, 2025, 00:18:47 »
Ha!  Sorry, didn't mean to be annoying.  Maybe someone in 1970 was trying to hot rod it a bit to keep up with the 280SLs?   ???
Duncan200
« Reply #10 on: June 10, 2025, 01:17:31 »
Given my daily is a 430hp Audi SQ7, as we say here, the 230 wouldn’t pull the skin off a rice pudding.
lowpad
  • USA, CT, New Preston
« Reply #11 on: June 11, 2025, 13:03:22 »
This was an interesting video of a very original & relatively unmolested late 230SL. One thing that cracked me up was the "wrinkle" below the RH windshield pillar. My car has this as well (through far less severe), which I tried to fix during its restoration, but it still shows up (and appears to be temperature dependent). Do other 230s have this issue as well? Drives me crazy at times -- but not crazy enough to try and fix it again (which will probably result in it looking worse...).
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
« Reply #12 on: June 12, 2025, 03:54:45 »
I don't see the wrinkle in the video. Can you grab a screen shot from the video that shows it?  I'll look at my car, as it's an Oct 66 build.
