Author Topic: Heater valve linkage to flap  (Read 2932 times)
Brandini
  • USA, WA, Seattle
« on: April 24, 2025, 00:23:01 »
I am in the process of repairing my heater core and discovered that the linkage is missing from the heater core valve to the flap. I am going to purchase one from vintageeuroparts.com but they have multiple sizes. Does anyone know how long it's supposed to be? I realize they can be adjusted.
Here are the sizes they have in stock:
1. 6" long
2. 9.5" long
- Brandon
Brandon
1964 Mercedes 230SL
Seattle, WA
dirkbalter
  • USA, CA, Corona
Re: Heater valve linkage to flap
« Reply #1 on: April 24, 2025, 03:37:55 »
This is what my linkage at the heater valve measured.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Brandini
  • USA, WA, Seattle
« Reply #2 on: April 26, 2025, 15:16:19 »
Thank you for this. I don't think the one Vintageeuroparts.com is correct as it looks different.
Does anyone know where I can purchase a linkage for the heater flap like the one in the picture? Is there a part number I can search for?
Brandon
1964 Mercedes 230SL
Seattle, WA
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #3 on: April 26, 2025, 19:05:48 »
Could you just buy one of the ones from VEP (assuming they're not crazy expensive), then cut down a piece of the correct threaded rod to the length Dirk shows?
             -David
-David Pease
« Reply #4 on: April 26, 2025, 21:48:11 »
I cannot find part number, I suppose it may be part of heat exchanger - it looks like it is just not there. If the ball joints are the same as in linkage, they are available. Rods are available too, question of cutting and threading them.
Fresnomike
  • USA, CA, FRESNO
« Reply #5 on: April 27, 2025, 01:54:29 »
I just went through this, and I ended up buying the throttle linkage ball ends from Authentic Classics. I bought two right hand threaded ends, then I bought some 5mm all-thread and cut it to size.
Brandini
  • USA, WA, Seattle
« Reply #6 on: April 27, 2025, 02:29:21 »
             -David
Thanks David...I found some on their website that is around $30. Still not cheap but should work once I cut it to the correct size.
Brandon
1964 Mercedes 230SL
Seattle, WA
Brandini
  • USA, WA, Seattle
« Reply #7 on: April 27, 2025, 02:31:00 »
This is also a good idea...thank you for the suggestion.
Brandon
1964 Mercedes 230SL
Seattle, WA
« Reply #8 on: April 27, 2025, 06:36:27 »
Throttle linkage ball ends at Mercedes are $7-8 item, please check A 000 993 04 61 at a dealer or classic center. They are available here in Europe, chances are they are also available in the US.
At SLS they are EUR 2.80, but then you would have duties and shipping.
Bshaunessy
  • Canada, British Columbia, Invermere
  • 1957 190 SL; 1970 280 SL; 1975 450 SL; 1971 300 SE
« Reply #9 on: April 27, 2025, 14:12:56 »
PIERCE MANIFOLDS located California (https://www.piercemanifolds.com) is a good source for fuel and heater system rods and ball connectors.   Good service as well.
