Please check out joining the
Emergency Contact List
for help during your travels!
Commercial Advertising
Just finished another custom pagoda wiring harness creative stuff
Topic: Just finished another custom pagoda wiring harness creative stuff (Read 4758 times)
lpeterssen
Vendor
Gold
USA, FL, Miami
December 17, 2024, 11:55:21 »
Dear friends
As I see you read all my custom wiring projects, here after I describe one I just completed for a famous restorer in France on his customer request.
Apart from the usual stuff I do always this one requested some special things:
Master & Slave door locks
. This a simple system that allows you to open or close both doors locks by actuating on the driver lock cylinder. If you insert your car key on driver door cylinder and open the lock, the passenger door lock will open at the same time. Also if you push a buttom on a key fob remote provided both doors will lock/unlock
Hidden magnetic kill switch.
Many of you have commented that do not thrust, at all, into an alarm system since they are prone to failure; which in my opinion, is most of the time related to a low quality installation. Nevertheless, this time the customer wanted a way to protect his car so we came up with the idea of a magnetic switch somewhere.
This is a switch which is more than hidden that activates a signal when you place a magnet over it. So we decided, in honor to the recent re-inauguration of NOTREDAM Church, to buy a small refrigerator magnet to place somewhere in a notorious place in the car, and behind it, is the magnetic activated switch.
This switch is a Normally Open one, and when closed by magnet action, it sends a ground signal to an array of original mercedes relays that in place take some actions.
One relay activates the fuel shutoff selenoid at injection pump. The other relay activates the low fuel reserve dashboard light. Both relays only draw power when ignition switch is on the run position. So this configuration will not deplete your battery when your car is sleeping. User will know that system is enabled when low fuel reserve light is on once ignition key is turned to run position.
For a burglar it is very difficult to resolve what is happening with the car that does not start; since fuel pump will be running, you will have spark, but car will not keep running. He may think is a matter of low fuel. It may start, with fuel available in injection lines, but car will stahl immediately.
So this is an ingenious way of protecting your car.
AC system.
Customer also added the harness ai specially developed for pagodas to run on a modern AC system, with all the control logic of a W109-6.3 with some other add ons.
Stereo system.
Customer added a very nice French FOCAL amplifier/speaker configuration paired with a retrosound.com head unit. It had some particulary high energy demands so the main harness was modified accordingly. So branches for headunit, amplifier and power antenna were added to main harness.
USB charging points.
User wanted USB charging points at central wood console and in the dashboard.
Fridge /freezzer
. This was also added in the trunk area, and a large 3mm2 line was embedded into rear harness. Fuses for this line and the one that feeds the stereo amplifier were installed on the driver side fender at the engine bay area.
So this was a great project that I enjoyed so much. Share with your friends
Detailed photos here
https://www.icloud.com/sharedalbum/#B2O5GV49auAnOa
Best regards
Eng. Leonardo Peterssen
Www.wiredoktor.com
Last Edit: May 05, 2025, 17:15:04 by lpeterssen
yves
Full Member
Silver
France, Poitou-Charentes
Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
Re: Just finished another custom pagoda wiring harness creative stuff
December 17, 2024, 13:23:57 »
Bravo! 👍Well done
Happy owner of a 69 blue 280SL , 63 FHC osb E-type , 55 FHC XK 140 to be restored...
Bonnyboy
Full Member
Gold
Canada, BC, North Vancouver
1969 280sl Euro 4sp LSD
Reply #2 on:
December 17, 2024, 17:31:33 »
This setup sounds pretty cool.
A fridge/freezer in the trunk tells me that either this car will be used for longer outings or trips to the owner's favorite fishing hole.
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
Jack the Knife
Full Member
Gold
USA, FL, Vero Beach
Reply #3 on:
December 17, 2024, 17:34:31 »
Sounds like really excellent work -- glad to have you doing this kind of thing in our community, Leonardo.
1964 230SL "Blue Note" -- #009785
2015 G550 "Milk Truck"
RAY
Full Member
Gold
United Kingdom, England, Bromley
Reply #4 on:
December 17, 2024, 18:40:26 »
What an interesting project completed to your usual high standard.
Bshaunessy
Full Member
Senior
Canada, British Columbia, Invermere
1957 190 SL; 1970 280 SL; 1975 450 SL; 1971 300 SE
Reply #5 on:
December 18, 2024, 03:53:19 »
Nicely done!🤙
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #6 on:
December 18, 2024, 08:15:50 »
Beautiful!
Do I see correctly? You both crimp and soldier the female spade connectors?
BobH
Full Member
Platinum
United Kingdom, England, MALDON
Reply #7 on:
December 18, 2024, 09:54:17 »
Well done yet again Leo, i love the fridge magnet idea
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
lpeterssen
Vendor
Gold
USA, FL, Miami
Reply #8 on:
December 18, 2024, 10:37:18 »
Dear Pawel
So long without talking to you…. Yes I always crimp with a special tool and solder terminals just to have a perfect long lasting connection.
Thanks for your nice comments.
Best regards
Leonardo Peterssen
Www.wiredoktor.com
lpeterssen
Vendor
Gold
USA, FL, Miami
Reply #9 on:
December 18, 2024, 10:38:58 »
Bob:
Many thanks , I also think that the Magnet / hidden switch was very creative and the implementation was perfect.
Best regards
Leonardo Peterssen
Www.wiredoktor.com
lpeterssen
Vendor
Gold
USA, FL, Miami
Reply #10 on:
December 18, 2024, 10:41:21 »
Many thanks for your positive feedback, specially mentioning my high quality standards……
Leonardo Peterssen
Www.wiredoktor.com
lpeterssen
Vendor
Gold
USA, FL, Miami
Reply #11 on:
December 18, 2024, 10:42:23 »
Thanks Ives
In honor to Notredam….
Best regards
L.Peterssen
Www.wiredoktor.com
lpeterssen
Vendor
Gold
USA, FL, Miami
Reply #12 on:
December 18, 2024, 10:48:20 »
To
Jack, Ray, and Bshaunessy
Many thanks to you all for your positive feedback
Best regards
L.Peterssen
Www.wiredoktor.com
