Author Topic: soft top large spring mounting lever  (Read 4694 times)
bluto2478
  • Italy, Lombardy, milano
« on: July 26, 2024, 14:43:59 »
good morning, I'm writing from Italy and I have a big problem: I'm restoring a ‘67 250 SL and while fitting the new soft o top I noticed that my chassis is missing both large spring mounting lever. This makes it virtually impossible to close the roof.
I read on this forum that it is a problem that has already happened to several owners. Many have solved it by going to the locksmith and having it rebuilt.
the problem is that i am missing both, and i have no idea what shape they are and how they can be assembled. can anyone help me?
thanks!
cfm65@me.com
  • Cape Town, South Africa
Re: soft top large spring mounting lever
« Reply #1 on: July 26, 2024, 15:53:57 »
I hope this helps,
Chris
Cape Town
Apologies, it seems you are looking for the lever, not the spring.
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
cfm65@me.com
« Reply #2 on: July 26, 2024, 16:05:14 »
Confirm it is part nr 31 you are looking for?
Unfortunately, I can’t assist, but having a picture might help.
Good luck,
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
bluto2478
« Reply #3 on: July 26, 2024, 16:55:20 »
thanks Chris.
I don't know if it's that... I read somewhere that it should have an L shape
dirkbalter
  • USA, CA, Corona
« Reply #4 on: July 26, 2024, 17:33:33 »
Unless someone chimes in before, I will post some pictures later on how these are mounted. You have to check that the holes in the soft top mechanism are good.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
cfm65@me.com
« Reply #5 on: July 26, 2024, 19:57:03 »
I am quite sure item 31 is the ‘L’ shaped part you are referring to. I am in the UK for a few weeks and should be back home in South Africa in September.
If you have not received your answers by then, I’ll have a look at my soft top and we will continue from there.
However, believe me, there are more experienced chaps on this forum than myself and I am convinced you will have all the answers by then.
Hang in there.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
GM
  • USA, CO, Boulder
« Reply #6 on: July 26, 2024, 23:14:59 »
I don't know if this is what you are looking for - I have more pictures if this is close
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
dirkbalter
  • USA, CA, Corona
« Reply #7 on: July 27, 2024, 17:40:06 »
one more, with the spring expanded, soft top mechanism folded.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
