Become a
Full Member
Emergency Contact List
General Discussion
Thermostat Housing Cap Gasket
Topic: Thermostat Housing Cap Gasket (Read 2889 times)
LindesayOne
Full Member
Regular
Canada, Alberta, Edmonton
May 30, 2024, 22:39:36 »
As I reassemble my thermostat housing I'm baffled by how a seal is meant to be achieved between the cap and the base of the housing.
Is there a gasket and/or o-ring that is/are meant to go here? If so, who sells it/them? Nothing appears when the usual vendors' catalogues are searched.
Any suggestions would be much appreciated.
1957 190SL 8500074 (RIP?)
1968 280SL 11304410006390 (RIP?)
1969 280SL 113044120011428 - Light Beige/Cognac
dirkbalter
Full Member
Platinum
USA, CA, Corona
Re: Thermostat Housing Cap Gasket
May 30, 2024, 22:44:19 »
Item # 43, O-ring.
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/50-cooling-system/50-c-cooling-system-280sl
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
LindesayOne
Full Member
Regular
Reply #2 on:
May 30, 2024, 23:57:30 »
Thanks Dirk......now that I inspect the the actual thermostat, it quickly becomes obvious that the o-ring is normally sold together with the thermostat, hence no separate listings.
Great parts illustration from SLS; must remember that!
General Discussion
