Author Topic: Speedometer flutters below 10MPH  (Read 6568 times)
gcw206
  • USA, WA, Seattle
« on: July 26, 2023, 21:00:32 »
1969 280SE W111 Coupe, with an automatic transmission.
My OE speedometer fluttered an acceptable amount below 10MPH.
Then I damaged the OE cable while assembling the dash.
The OE cable was replaced with a non OE cable.
Then it skipped a lot, and the new after market cable was replaced with another by the same vendor.
All worked pretty well for a while.
Now my speedometer flutters a lot below 10MPH.  (Got worse over past year or so.)
It is either the gears in the automatic transmission; the cable; or the head unit in the dash.
I have found an OE MBZ NOS cable, but am I looking in the right place?
Thanks, Galen
kampala
  • USA, CA, Hermosa Beach
Re: Speedometer flutters below 10MPH
« Reply #1 on: July 31, 2023, 01:27:11 »
There is a lot written about this issue on this site.  Try the search “bouncing speedo”
Or similar terms to bouncing.  You should find a lot of info.
250sl - later - manual
280sl - 1971 - Auto - LSD
« Reply #2 on: August 01, 2023, 04:52:18 »
Try loosening it up a bit at one or the other end.
gcw206
  • USA, WA, Seattle
« Reply #3 on: August 10, 2023, 18:37:26 »
I removed the speedometer head and cable;
Took to bench, hooked up cable to a variable speed drill;
Speedometer still jumped at low speeds;
Decided that transmission sending unit was not the issue;
I bought a NOS MBZ OE speedometer cable;
Installed, and problem solved.
