Author Topic: Gas cap not locking  (Read 4714 times)
AAR
  • United Arab Emirates, Ash Shāriqah, Sharjah
    • Instagram Profile THE280SL
Gas cap not locking
« on: March 22, 2023, 13:18:13 »
My gas cap does not lock although the the key is normally turned from right to left.
The issue is that it keeps coming off easily
Not sure if i am not able to lock it correctly or there is an issue
Mercedes Benz 280SL 1971
Creating a 280SL community in instagram: @the280sl
Re: Gas cap not locking
« Reply #1 on: March 22, 2023, 13:43:58 »
When you lock the cap, what is supposed to happen is that the chrome top spins freely and does not engage the rest of the mechanism. I would try to figure out why this is not working on your cap. Maybe with some penetrant into the lock cylinder, and the rest of the cap, to try and get the locking mechanism back 'in action'. If that fails, try taking it to a locksmith to see if they can fix this. New caps are pricey these days I believe.
AAR
« Reply #2 on: March 22, 2023, 15:30:22 »
What i actually do is move it clockwise and with the “tick” sound i lock it but when i remove anti-clock wise it gets losen up and removed.
Yes new ones are expensive i was searching ebay and some websites.
« Last Edit: March 22, 2023, 16:15:55 by AAR »
« Reply #3 on: March 22, 2023, 17:56:26 »
What i actually do is move it clockwise ...
Move "it"?  Move (rotate) the whole cap clockwise, or rotate just the key in the cap?
« Reply #4 on: March 22, 2023, 18:53:42 »
From memory I think you have to hold the cap as you turn the key, so that it locks (if it's working). One of those many things better explained/looked at visually!
AAR
« Reply #5 on: March 23, 2023, 08:10:15 »
I rotate the whole cap clockwise and then lock it with the key.
H. Keith Henry
  • USA, VA, Yorktown, Va
« Reply #6 on: March 23, 2023, 19:53:36 »
My cap is fine once it is locked, but it's owner (me) is still trying to learn the best way to lock it. Not a good look for the "cool guy with the cool car." Ha.
1970 280 SL, auto, US spec, 050 white with burgundy interior and soft top. Originally special order, white on white on white tex. Manufacturing date May 1970
2002 Mercedes C320 wagon
1989 Honda Civic wagon
1979 MG Midget, original owner
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #7 on: March 24, 2023, 17:11:53 »
I had similar issues and found if I push the cap in then rotate and lock it it works fine. you may have to so that for a while to free up what ever blocks it due to old age :)
Dieter
George Lollar
  • USA, VA, Fairfax Station
« Reply #8 on: March 25, 2023, 02:05:33 »
I had a similar problem a while back due to excess friction between cap and fill pipe, solved with a Tyvek washer added into the cap.
George Lollar
1970 280SL Green/White
1994 E320 Coupe
AAR
« Reply #9 on: March 27, 2023, 18:23:20 »
  :D Then i think am also learning the best way to lock it.
AAR
« Reply #10 on: March 27, 2023, 18:24:52 »
Dieter
Thanks for the tip Dieter
