Hello Sead,
attached is a copy of the spare parts list that you probably had in mind.
The problem is that the lists show a
total of eight (
screws per box:
DIN 7981: 4 each 4.2x9.5 mm + 2 each 3.9x13 mm
DIN 7982: 2 each 4.2x13 mm
The four 13mm long screws are chrome plated (DBL 8454) whereas the shorter 9.5mm screws are "high-polish galvanized-iridescent passivated" (DBL 8451-21).
The clip nuts for the different screws (p/n 0009940445 replaced by 0009943345) are for 4.2 mm sheetmetal screws. Have not found a 3.9 clip nut only 2.9; another puzzle.
However, there are only six screw holes in the box, four on the bottom and two on the top.
Do you know how to put eight screws into six holes?
I don't and I have given up long time ago to make sense of it.
Use whatever you like best.
But I am really interested to see the rubber buffer that you bought from Mercedes.
