Author Topic: Side window jammed  (Read 4025 times)
MP
  • United Kingdom, England, Devizes, Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
Side window jammed
« on: October 07, 2021, 15:35:14 »
I have a side window  jammed at nearly  full up it will move about 1" up and down.
I would be grateful for any ideas on where it is stuck I am hoping  to fix it in without taking it apart.
Maurice
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
Re: Side window jammed
« Reply #1 on: October 07, 2021, 17:54:44 »
Probably too much play or a window guide has come loose, unfortunately the solution is to open the door and adjust/repair.
MP
« Reply #2 on: October 08, 2021, 08:48:04 »
Thanks Peter
2000 Ducati 748s
1970 Ducati Monza
gordon
  • United Kingdom, England, Burntwood
« Reply #3 on: October 08, 2021, 15:40:41 »
This is what you'll find inside. ( I'm about to put mine back together)
gordon
« Reply #4 on: October 08, 2021, 15:42:25 »
Another photo
MP
« Reply #5 on: October 10, 2021, 07:45:22 »
Thanks Gordon, does anything go in the the channel before the glass
2000 Ducati 748s
1970 Ducati Monza
gordon
« Reply #6 on: October 10, 2021, 13:17:39 »
The metal jaws ( with plastic inner liners) slide  on the inclined metal rails at each side and also in the guide in the top of the slide rail adjacent to the A post.
The largest guide on the glass was missing on my driver's door and the other was loose as we're both on the passenger side.
I hope this helps.
« Reply #7 on: October 10, 2021, 13:53:18 »
mazmonza, when I was doing the glass replacement after mine broke, I went to the drawings of doors at MB EPC and on SLS and I bought all the plastic and rubber parts that are there and replaced them for new ones. Quite a lot of them there.
Also the clips rubber bumpers holding rods for locks.
There are rubber or fabric stripes between the glass and a rail holding it from the bottom. There are also 4 bushings going through the orifices in the glass for screws.
The jaws replacement process is very well described in the Tech Manual.
MP
« Reply #8 on: October 11, 2021, 16:01:28 »
Thanks Pawel
2000 Ducati 748s
1970 Ducati Monza
