Author Topic: Electronic Ignition system  (Read 4291 times)
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« on: August 03, 2021, 19:16:41 »
Hi all,
I will update the ignition system with an electronic one... for my 230SL
Couple of products are on the market, from a brand new electronic distributor, including a new coil and amplifier (250/300€), to simple sensor (i guess Hall effect) replacing the breakers inside the original part, for just 1/3rd of the price...
I assume that from different prices we can expect different results...
Which one do you advice ?
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
Re: Electronic Ignition system
« Reply #1 on: August 03, 2021, 20:48:47 »
123Ignition is very popular… just search the forum…
« Reply #2 on: August 03, 2021, 21:48:52 »
123 for me. I had a Hall effect one but was not as good.
Merc_Girl
  • United Kingdom, England, Godalming
« Reply #3 on: August 03, 2021, 21:55:27 »
I’ve had the new electronic ignition installed on my 230SL. Much improved starting
I believe for my transformation this required a different coil and distributed, plus a little box thing (ballast resister?) which I have no idea what it does but came as part of the kit!!, 😉
Here is a link on the forum to similar query
https://www.sl113.org/forums/index.php?topic=30932.0
230SL
Figoulu
« Reply #4 on: August 03, 2021, 22:10:21 »
Thanks to all 👍👍👍
1965 230 SL
WRe
« Reply #5 on: August 04, 2021, 06:19:14 »
there are two advocating camps in the German Pagodentreff:
For reasons of originality and if the distributor is still in order, Pertronix is ​​recommended, if not the 123-ignition.
In my opinion, the likelihood of a good distributor after 50 years is rather unlikely and you should therefore overhaul it before you want to use Pertronix.
I have been using a 123-ignition for more than 10 years without any problems.
...WRe
Figoulu
« Reply #6 on: August 04, 2021, 07:29:01 »
I’ll certainly go for a 123 unless another seriously bad feedback
One thing I need to double check is the correct ref for my 230 from 1965 👍👍
1965 230 SL
« Reply #7 on: August 05, 2021, 16:14:34 »
...the likelihood of a good distributor after 50 years is rather unlikely and you should therefore overhaul it before you want to use Pertronix.
SPOT-ON!  EXACTLY!
...which is why I had my -050 overhauled prior to installing the Pertronix. There's nothing more frustrating than trying to solve some ignition issues by throwing a system like a Pertronix onto a distributor that itself is worn and in need of an overhaul.
Sure, I'd love a 123 but my refurbished -050 with the Pertronix seems to be doing well!
