Author Topic: In search of Clock  (Read 5121 times)
fsalazar8187
  • USA, VA, Woodbridge
In search of Clock
« on: July 19, 2021, 02:44:56 »
Hello I am currently searching for a replacement clock or it’s internal parts .
My clock runs but has to be winded to do so .
Thanks everyone !!
Re: In search of Clock
« Reply #1 on: July 19, 2021, 17:44:11 »
There are a few articles online on how to fix a Kinzle clock.  The best fixes involve a resistor and capacitor to preserve the points.
perry113
  • USA, NY, Rensselaer
« Reply #2 on: August 09, 2021, 19:22:52 »
Send your clock to Morris at West Valley for rebuild.
He can also update it so it will keep accurate time.
That is your best bet.
see:
https://www.westvalleyinstruments.com/
Peter Perry
1969 911T Tangerine
TJMart
  • USA, NC, Matthews
« Reply #3 on: August 10, 2021, 14:09:04 »
I have a Clock that you could use for replacement parts. PM if interested.
Tony
1970 280SL, 4 Speed
lreppond
  • USA, CA, San Leandro
« Reply #4 on: August 11, 2021, 22:02:54 »
I recently had my clock repaired at Classic Clocks (Jeffrey Read) in Houston, TX.  I absolutely could not be more pleased.  Not only does the clock work but Jeffrey spent almost a week fine tuning it to keep accurate time.  Right now it works amazing but over the course of time it will probably start to lose time.  Typically these clocks require maintenance every 7-10 years.
Most speedometer shops want to remove the internal mechanism and replace it with a quartz movement.  It’s more accurate and requires less maintenance.  Such movements simply go against my grain in attempting to keep my car as original as possible.  Others feel differently.
Jeffrey told me that these old VDO Kienzle clock mechanisms are essentially bullet proof and he’s never had one he couldn’t repair.  As Shvegel pointed out, a resistor and capacitor almost always need to be replaced, maybe the bulb too.  The winding mechanism on your clock is probably just dirty and needs cleaning and lubrication (gears, too).
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
« Reply #5 on: August 12, 2021, 07:20:16 »
https://www.sl113.org/wiki/Electrical/Clock
Useful repair tips in our own Technical Manual
m300cab
  • USA, Pennington New Jersey
« Reply #6 on: August 12, 2021, 18:10:02 »
thank you for the info!
Michael Parlato
Rahul
  • Bermuda, Devonshire, Paget
  • 1971 280SL automatic #571, parchment
« Reply #7 on: August 13, 2021, 01:02:51 »
+1 for Jeffrey's work, I used him recently and he was great to work with, and very reasonably priced.
1971 280SL auto #571 over parchment
m300cab
« Reply #8 on: August 28, 2021, 00:26:30 »
I have a nice clock if you have not found one yet.
Michael Parlato
Rolf-Dieter ✝︎
  • Canada, ON, London
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
« Reply #10 on: August 29, 2021, 09:27:53 »
You could also try getting these aftermarket lookalikes sold by all Mercedes classic parts specialists for around $200. They look virtually the same, are an exact fit and being quartz you fit them and forget them.
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
