Author Topic: Body cut-outs in rear  (Read 3470 times)
dirkbalter
  • USA, CA, Corona
« on: May 25, 2021, 19:12:38 »
I am working on the insulation / sound dampening of the cabin. I intend to also add some insulation to the rear and I am wondering, what is the purpose of the cuts out in the rear (Kinderseat) area, picture 2? Do I ever need access the these? I am sure it was discussed before but I  searched the forum and could not find anything.
Thank you for you help.
« Last Edit: May 25, 2021, 19:58:25 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Re: Body cut-outs in rear
« Reply #1 on: May 25, 2021, 21:51:46 »
it is not used in most of the cars.
For originality I did not glued insulation material, but I filled it with very thick insulation material that can be removed if necessary. Same in the inner wheel wells
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #2 on: May 26, 2021, 04:20:19 »
I sprayed my cavities with rockerguard, then made a nice padded bag for each side and then use them for my emergency kit - all the stuff you need in an emergency - zap straps, some tools like wrenches, pliers electrical tester, screw driver, emergency blanket, different types of wire - electrical tape, tire plugs, road flare, fuses etc.   look up what to take on a rally and basically thats what I put in there.  I think there is even a couple tiny bottles of Buffalo Trace Bourbon, couple hot wheels for cranky kids and a couple knives (filletting and a chef's knife and a sharpener)   there is nothing worse than showing ap at a bbq and the hosts knives are so dull they don't cut.
If you leave your car out in the rain this area will fill up with water so I didn't glue any foam in there.
Both of my cavities were rusted out and the previous owner just filled the bottom up with chicken wire, newspaper and bondo.  I removed that and made new bottoms out of galvanized metal and welded them in.
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
dirkbalter
  • USA, CA, Corona
« Reply #3 on: May 26, 2021, 16:13:29 »
Thanks guys,
Peter, didn't think of just laying the pad in, interesting. I think the approach and the materials used for sound / head dampening  have come a long way since the 60'ties. I am using a 5mm thick 3 layer material with an aluminum sheet embedded in-between. Easy to work with and forms nice around the metal. Even though I like originality, in this area I believe there is some room for improvements.
Ian, very funny. My rear area was a mess too. It took quiet a bit of sheet metal manufacturing to get it back into shape.
However, I still don't know what the two port holes are for. Hard to believe they are just for possible water drainage.
« Last Edit: May 26, 2021, 16:50:03 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #4 on: May 27, 2021, 11:16:01 »
Those cutouts are simply drains for the primer when they dipped the body.  Never used again.
dirkbalter
  • USA, CA, Corona
« Reply #5 on: May 27, 2021, 14:35:32 »
Perfect, thank you.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
