Author Topic: Simple "kill switch"?  (Read 4779 times)
GM
  • USA, CO, Boulder
« on: May 02, 2021, 01:13:31 »
If I remove fuse #4 for the fuel pump is this an effective way to immobilize the car while parked overnight at a hotel?
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
Re: Simple "kill switch"?
« Reply #1 on: May 02, 2021, 09:12:24 »
I will write a PM on what I did. Not very clever, obviously, but just an idea.
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #2 on: May 02, 2021, 17:49:39 »
It is definitely a very effective way I have the first-hand experience when my number 4 fuse failed and I had to be picked up by a flatbed truck. Then that is another story.
I will also PM you what I do to disable starting the car.
Dieter
FGN59
« Reply #3 on: May 02, 2021, 17:52:28 »
I would love to receive PMs too from both of you regarding the same subject, if I may… Thanks!
AndrewB
  • United Kingdom, Channel Islands, Forest, Guernsey
« Reply #4 on: May 02, 2021, 18:21:52 »
Likewise, I would be very interested.
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
Rolf-Dieter ✝︎
« Reply #5 on: May 02, 2021, 21:08:05 »
François and Andrew, PM posted to you
Dieter
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #6 on: May 02, 2021, 21:28:41 »
It seems everybody is being secretive about their kill switches 🤣. This has been discussed several times.
Here is just one post.
https://www.sl113.org/forums/index.php?topic=11000.0
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
« Reply #7 on: May 05, 2021, 10:54:28 »
Another effective way if you have a Bluetooth 123 ignition is the immobilizing facility that it has, whereby you immobilize the car with your mobile phone App and then have to input an unlocking code to get it going again..... this is a side benefit of installing an 123 ignition - Bluetooth enabled though.....
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
specracer
  • USA, MA, Duxbury
« Reply #8 on: May 05, 2021, 23:19:52 »
I dont leave my car anywhere..... So Ill share publicly. A prior owner added a race car master switch to one of the battery cables. Its only visible when on the ground at the bumper. Ill likely remove it, but have not yet bothered.
