Author Topic: Injection pump refurbishing adress in France or Europe?  (Read 2239 times)
yves
  • France, Poitou-Charentes
  • Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
« on: September 01, 2020, 13:41:24 »
I have some difficulties to start the engine when cold,  ( the engine starts after 10 seconds without throttle and after a first trial of 10 seconds too ) the engine is ok when hot .  i have replaced the 6 sparks plugs, checked the distributor by a mechanic and this one says that the pump needs to be adjusted ( he says also that the "fumes" are very black at the exhaust and the old plugs were black too.
AFAIK  the pump refurbishing is a tricky job , so i'd be very happy to have an adress here in France or Germany  at a professional mechanic for that...!
Thank you !
« Last Edit: September 02, 2020, 14:50:47 by yves »
Happy owner of a 69 blue 280SL ,  63 FHC  osb E-type , 55 FHC XK 140 to be restored...
VincentR
Re: Injection pump refurbishing adress in France or Europe?
« Reply #1 on: September 01, 2020, 13:50:43 »
You can contact : http://www.etoile67.com/
They are specialized in old Mercedes injection.
They are serious and professionnal.
Have a nice day !
Best regards.
Vincent R
280sl 1970
Besançon / France
yves
« Reply #2 on: September 01, 2020, 16:32:18 »
Thank's Vincent ;)
Taleb
  • USA, NY, SPRINGFIELD GARDENS
« Reply #3 on: September 01, 2020, 21:01:09 »
The right company is www.koller.de speak with Rainer stahel +49 172 3442206
Good luck
WRe
« Reply #4 on: September 02, 2020, 06:37:11 »
see https://www.sl113.org/forums/index.php?topic=30847.msg223857#msg223857.
CMG are doing a pre-analysis with error report for ~150€.
...WRe
