with our official
Pagoda SL Group logo
from our official partner.
W113 front brake caliper repair kit
Topic: W113 front brake caliper repair kit (Read 3259 times)
Mohan58
Associate Member
Regular
Malaysia, Selangor, Petaling Jaya
August 30, 2020, 02:34:48 »
Hi guys,
Can anyone tell me if the front brake caliper repair kit on a W113 is the same as any other merc model?
Cheers,
Mohan
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
Leester
Full Member
Silver
USA, VA, Lorton
Re: W113 front brake caliper repair kit
August 30, 2020, 18:11:37 »
Hello Mohan, you don't tell us which model you have and there may be differences. At least some 230SLs had Girling calipers. I am not familiar with these calipers but it seems that many of the Girling calipers have been replaced with ATE calipers.
Most later 250SL and 280SLs have ATE calipers and I believe all front ATE calipers (at least for W113s) have 57mm pistons. The ATE part number for the 57mm ATE caliper kit is 13.0441-5718.2. (at least that's what my caliper kit is marked). I'm quite sure that that W108s of the era used the same caliper kit.
Many folks use the SLS website for part descriptions. If you cut and paste the link below into your browser you will see SLS's variations.
https://www.sls-hh-shop.de/main/de/42-bremsen-42-a-bremse-r-der-c-3_2336_70
Looks like SLS part # 242015 is the ATE kit at 66.56 euros and 242815 is an aftermarket kit at 28.98 euros each. If you need the If you need the Girling kit it looks like they also have that. Hope this helps.
Lee Backus
1963 220SE Cabriolet
Mohan58
Associate Member
Regular
Reply #2 on:
August 31, 2020, 01:35:41 »
Hi Leester,
Apologies for not stating my model. Mine is the 250SL. Thanks for the information. Its really helpful. Reason why i asked is when i bought the front wheel bearings, the guy gave me the 115 model bearings. When i asked he said they are the same.
Thanks once again.
Cheers,
Mohan
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
sandcrab59
Full Member
Silver
USA, MA, Lunenburg
Reply #3 on:
August 31, 2020, 16:31:42 »
I have not checked my 72 220D lately 115 Chasis , I believe the calipers are the same.
71 280SL-8 Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
sandcrab59
Full Member
Silver
USA, MA, Lunenburg
Reply #4 on:
August 31, 2020, 16:32:41 »
They are ATE's. Forget to add that in my last Post.
71 280SL-8 Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #5 on:
August 31, 2020, 16:43:37 »
When I put old part number of front caliper (A 001 421 02 98 or 03 98) or new part number (A 001 421 81 98 or 82 98), the system shows
a lo
t of versions form 108, 109, 110, 111, 113 (certainly), 114 and 115.
Mohan58
Associate Member
Regular
Reply #6 on:
September 01, 2020, 03:10:20 »
Thanks Tom.
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
Mohan58
Associate Member
Regular
Reply #7 on:
September 01, 2020, 03:12:12 »
Thanks for this Pawel.
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
sandcrab59
Full Member
Silver
USA, MA, Lunenburg
Reply #8 on:
September 01, 2020, 13:01:25 »
I think whichever vendor you use, a 230, 250, 280SL will bring a higher price.
So if I am correct about the 115 chasis the price might be lower.
It is only a guess.
71 280SL-8 Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
