Author Topic: Sparkplug discontinued?  (Read 8029 times)
col320ce
« on: June 06, 2020, 09:37:18 »
https://www.ngk.com/product.aspx?zpid=9397
Are nkg also stopping manufacturing of the non resistor plugs?
Time to stock up
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Sparkplug discontinued?
« Reply #1 on: June 06, 2020, 09:42:15 »
Your link is broken.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #2 on: June 06, 2020, 09:45:05 »
Yep, does not work...
Alex D
  • USA, NC, Cary
« Reply #3 on: June 06, 2020, 10:51:53 »
Yes, I spoke to NGK customer service, they said they are no longer producing non resistor spark plugs, once the exisiting inventory is gone, it's gone.
Alex D
1967 250 SL
Original 140K mi
181 Light Beige, with  112 Turquoise Interior
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #4 on: June 06, 2020, 11:56:02 »
W7DC Bosch are still available many places.  I just did a google search.  I have been using them.
Brad
1961 220 Sb
1966 230 SL
2019 E 450 4 Matic
2022 GLC 300 4 Matic
« Reply #5 on: June 06, 2020, 12:25:46 »
Resistor plugs work just fine.
« Reply #6 on: June 06, 2020, 22:10:00 »
Bosch started suppling the W7DC (non-resistor) spark plugs again. Most likely you will have to get lucky to find them or order them from the dealer. There is a MB part number assigned to them, anybody?
Using resistor plugs will work but you add 5,000 ohm resistance to each spark plug circuit. The rotor is 5,000 ohms, the spark plug wire end at the distributor is 1,000 ohms, the spark plug wire end at the spark plug is 1,000 or 5,000 ohm and now with the resistor plugs you add another 5,000 ohms.  Early factory non-transistorized ignitions spec maximum resistance in each spark plug circuit to 13,000 ohms. So with everything new you are already near or over the factory limit and have no cushion for age and wear  of parts and weather conditions. At the very least you have lost all of your safety margin. Now if you have carbon spark plug wires or carbon coil wire you add a lot more resistance on top of that. Later W113 cars with factory electronic ignitions had a higher voltage and were allowed 19,000 ohm resistance per spark plug circuit. Most of these cars can use the 5,000 ohm spark plug wire ends. If you have to use resistor spark plugs you should upgrade your ignition coil and ballast resistor to supply more voltage. In the end, these engines were designed to use non-resistor spark plugs with the original ignition systems. The next time you have a cold start on a damp cold morning you'll be glad you had a hotter spark from less resistance or a hotter ignition.
« Reply #7 on: June 07, 2020, 08:08:12 »
Mercedes part number for Bosch W7DCO is A 003 159 12 03. It can be found under Air Pollution Control parts list.
Mercedes part number for Bosch W5DCO is A 003 159 14 03.
I would, however, be careful - if a dealer don't have this particular plug, they will give you replacement.
I think it is easier to find the plugs we are looking for in the stores specializing in motorbike parts.
« Last Edit: June 07, 2020, 08:31:52 by Pawel66 »
Montreal V8
« Reply #8 on: June 07, 2020, 18:15:25 »
    The main problem I foresee is is for owners of vintage/ classic, magneto equipped motorcycles, as resistor plugs put an extra load on the armature winding, and a reduced spark intensity.
« Reply #9 on: June 07, 2020, 18:16:38 »
I think they will re-appear in a box called "Classic", triple the price.
« Reply #10 on: June 08, 2020, 03:51:25 »
I think Pawel has it right. Bringing a product back like that is all based on demand though. If the resistor plugs don't end up creating a big issue and no one complains, you will never see another non-resistor plug from NGK. But if enough people complain......yep triple the price.
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #11 on: June 08, 2020, 12:01:34 »
Just buy the W7DC.  They can still be found.
Brad
1961 220 Sb
1966 230 SL
2019 E 450 4 Matic
« Reply #12 on: June 08, 2020, 13:43:54 »
I bought a few more just in case but I use the W8DC. Just a bit hotter. Still they are $8/ea and that ends up being being $50 a set of six. Not cheap by any means. But I have enough to last me for a very long time now. Thanks for the tip about NGK.
Saman 280SL
  • USA, CA, Los Angeles
« Reply #13 on: June 08, 2020, 16:46:32 »
If you have converted to a Petronix electronic ignition system it's ok to use non-resistor?
1969 280SL 050 Cognac
1970 280SL 180 Black
1971 280SE 3.5 180 Black 111
1970 280SE  LG 904 Cognac 111
1970 280SE LG 180 Bamboo 111
1989 560SL
1994 E320 Cab.
124-1995 E320 Cab.
251-R350-4Mat
neelyrc
  • USA, AL, Birmingham
« Reply #14 on: June 09, 2020, 01:44:39 »
I picked up a set of the NKGs yesterday and another set today.  Thirty bucks well spent.  With a third set still on my parts shelf I think I am fixed for a while.
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
mrfatboy
    • Mrfatboy
« Reply #15 on: June 09, 2020, 01:46:40 »
🤣 I can't resist 🤣
Signal Red
4 Speed
kampala
  • USA, CA, Hermosa Beach
« Reply #16 on: June 09, 2020, 02:05:29 »
Is this going to be like toilet paper?  Are we gonna have a stockpiling of plugs?  Is Costco going to limit them to one 48 pack per family?
A while back rockauto was selling the plugs I like ( ngk 7832), for about a $1.10  so I picked up enough to get me through many years for both cars.   These are the hotter bp5es.
250sl - later - manual
280sl - 1971 - Auto - LSD
Aslam
Paul & Dolly
  • i Car
« Reply #17 on: June 09, 2020, 08:36:54 »
I have used NGK BP5ES successfully for a while now, the box says NGK BP5ES (6511)  ,
Is there any difference with NGK BP5ES (7832) ?
If you search for NGK 6511 or 7832 you get BP5ES
Any one any idea why ? or is it that 6511 and 7832 are just numbers used in different markets ?
6511 are still easily available  in UK for around £2.00 a plug.
Any thoughts ?
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
WRe
« Reply #18 on: June 09, 2020, 09:37:11 »
it's really confusing!
If you look in the official European NGK catalogues BP5ES spark plugs have the number "6511".
Same spark plug in US catalogues has "7832".
If you look in the different NGK part finders
European https://www.ngkntk.com/part-finder/produktfinder/PKW/ZK_BENZINER/ and
US: https://ngksparkplugs.com/en/part-finder) you'll find different recommendations for a standard spark plug,
e.g. for 280SL you'll find:
European: BP7ES
US:          BPR6ES
In those cases a former IBM tutor used to say: "Why the difference? To confuse the Russians!"
Btw: The information that NGK no longer will produce non-resistor spark plugs is at least 1 year old. But they are still on the market. Here for 1,25-1,50€/ea.
...WRe
TJMart
  • USA, NC, Matthews
« Reply #19 on: June 09, 2020, 17:20:39 »
I just picked up 12 NGK BP5ES 7832s at Advanced Auto Parts for $2.49 each. Bosch I could not find.
Tony
1970 280SL, 4 Speed
neelyrc
« Reply #20 on: June 09, 2020, 23:35:30 »
Any thoughts ?
Quite confusing.  I also have BP5ES plugs with the number 2140 on the box????????
Ralph
Italy
« Reply #21 on: June 09, 2020, 23:36:24 »
Same spark plug in US catalogues has "7832". .....
Here is your answer Wolfgang:
Why Do NGK Plugs Have Two Numbers?
Many spark plug brands, including NGK, have two different ID numbers assigned to spark plugs - a 3-5 digit stock number and a longer alphanumeric part number.
The alphanumeric part number identifies the spark plugs specifications and is printed on both the spark plug and the box.
The stock number is used by distributors and retailers to aid in stock management, as the alphanumberic number would be difficult to manage inventory by. This number is found only on the box and has no relation to the spark plugs features or dimensions.
https://www.ngk.com/learning-center/article/825/why-do-ngk-plugs-have-two-numbers
The alphanumeric number decoding is in the technical manual: https://www.sl113.org/wiki/Electrical/SparkPlugs
Alex D
  • USA, NC, Cary
« Reply #22 on: June 10, 2020, 00:28:14 »
Yes, Alfred is correct.  While trying to stock up on a few extras twice I was sent the wrong plugs BPR6ES instead of the non resistor plugs I ordered, both times I had to return.  They had a mix up in the 4 digit numberic stocking number.
Alex D
1967 250 SL
Original 140K mi
hansr433
  • Italy, Tuscany, Torrita di Siena
« Reply #23 on: June 10, 2020, 05:37:36 »
Very often the same item will have several part numbers.  The purpose is to discourage and track grey market imports.  I found this to be true with particular Canon inkjet cartridges, which sell for much more in Europe than in NA.  Same with batteries like Duracell or Energizer.  Different market=different distribution model=different price.
Hans
1963 220SE Cabrio (Exterior: Navy MB 332, Top: Haarz Navy, Interior: 482P Sahara Beige)
1963 BMW R69S
WRe
« Reply #24 on: June 10, 2020, 07:14:10 »
thank you Alfred!
The "BP5ES 2140" has a non-removable SAE-terminal, fixed nut. Corresponding to NGK's own numbering scheme - maybe for Europe only - these sparkplugs should have a "B" instead of an "S" (for standard) in their name. Attached two NGK numbering systems with and without this special detail.
...WRe
« Last Edit: June 10, 2020, 07:34:56 by WRe »
« Reply #25 on: June 20, 2020, 05:09:36 »
Hello Wolfgang,
if you look closely under the column "S" it states "Firing End Construction", the fixed terminal nut is on the other end.
Since this NGK nomenclature is so confusing I inquired with the NGK Technical Support-USA why some BP5ES have a removable terminal and on others it is fixed. Here the reply:
"Thank you for your inquiry.
There are different terminal types for spark plugs. We no longer offer BP5ES in a loose design, the type where you can unscrew the tip, so the solid terminal type is normal for this plug. The loose design has superseded to the solid terminal type, stock number 7832 to stock number 2140.
 Please let me know if you have any additional questions."
I followed up by asking whether there is a decoder that would tell us which stock number for other plugs has the removable terminal nut but received no further replies.
Thus anyone searching for the correct BP5ES look for stock number 7832. Or perhaps for stock number 6511 as Paul noted earlier.
And if you search for BP6ES then find stock number 7333 and DO NOT buy the new stock number 7811, it has a fixed terminal.
Given that confusing state of part numbers it will be best to ask specifically whether the plug has a removable terminal nut.
« Last Edit: June 20, 2020, 05:19:33 by 66andBlue »
FGN59
  • France, Provence-Alpes-Côte d'Azur, Marseille
« Reply #26 on: June 20, 2020, 22:16:10 »
I recently purchased 2 sets of plugs on Amazon, one of BP5ES (6511) and the other BP6ES (7811). Both types have removable terminals screwed onto the external threaded part (lead?) that fits into the connector of our cars. Once The terminals are removed, they fit perfectly.
François
1994 Toyota Land Cruiser SW HDJ80 4.2L diesel
sold:
1969 280SL US specs, 4-speed manual, beige-grey (726H), parchment leather
1962 Jaguar MK2 3.8L (4.2L XJ6 engine), black, tan leather interior
1968 Peugeot 204 roadster, white, black interior
1955 Massey Ferguson TEF20 diesel tractor 😁
« Reply #27 on: June 21, 2020, 04:33:31 »
Good to know that you found a 7811 with a removable terminal nut.
This is another proof that NGK's numbering is out of wack.
Here are the details from another NGK information site (I added the coloring to highlight):
BP6ES - NGK Replacement Spark Plug Sparkplug - NEW No. 7811
Spanner Size : 20.8 mm (21mm)
Thread : M14
Thread Length : 19mm
Top Connection : FIXED top nut (Terminal Nut)
Spark Projection : 3mm
Nickel Centre Electrode
1 Single Earth Electrode
Non Resistor Type
Seat Type : Gasket Washer
« Reply #28 on: June 22, 2020, 15:42:04 »
Hmmm.
I stock both BP5ES and BP6ES in my "kit".
Stock #s 7832 and 7333 respectively. With removable tops.
My car runs better with the BP5ES, so that's what I just bought for a lifetime supply. I do have a new set of the BP6 as well.
2022 Ford Escape Hybrid
alpina
  • Spain, Asturias, Villaviciosa
« Reply #29 on: June 22, 2020, 18:48:55 »
I  recently bought NGK BP5ES (6511) from Amazon here in Spain and they have removable tops.
Atazman
  • USA, Ca, Pleasanton
« Reply #30 on: June 23, 2020, 04:39:33 »
Who would have thought..........first toilet paper and now spark plugs!   ;D
I joined right in thinking it is time to change my BP6ES plugs for BP5ES.  Went to one of my favorite places (Rock Auto) and bought apparently their last "5" BP5ES for $0.81/each.  I know..... how much good will "5" spark plugs do me??  They arrived this past week.
Well.... I need  at least 1 more BP5ES plug, so ordered  from EBAY.  Also arrived this past week, only it is a BPR5ES plug.  I sent it back.
Still on the hunt for one more BP5ES.
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
neelyrc
« Reply #31 on: June 23, 2020, 05:36:05 »
Try Advanced Auto Parts, physical stores, not on line.  A few days ago when I bought the last set of 6 from one store they had two single plugs still on the shelf.  Another of their stores I checked also had two only.  You might get lucky!
Ralph
Italy
UJJ
  • USA, CA, Grass Valley
« Reply #32 on: June 23, 2020, 13:29:55 »
I just got 12 from Rock Auto for $1.48 each.
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
« Reply #33 on: June 24, 2020, 20:36:41 »
PM sent.
« Reply #35 on: June 24, 2020, 20:42:24 »
Still available on Amazon for about $3.00 each......
Both AlexD and myself tried this. They send the Resistor plugs!!!
mrfatboy
    • Mrfatboy
« Reply #36 on: June 24, 2020, 20:45:15 »
This happened to a friend of mine also.
Signal Red
4 Speed
jeblack123
  • USA, GA, Albany
« Reply #37 on: June 24, 2020, 21:17:50 »
Thank you. I stand corrected......
« Reply #38 on: June 24, 2020, 22:37:02 »
I've had the same plugs in my car for over ten years and I've never had them out to even look at them. Once you get your ignition and fuel ratios set right pugs should last a long time. I've probably put 30,000 miles on the car in the last ten years.
1988 560SEC
Mike K
  • South Africa, Gauteng, Johannesburg
    • Mike Kirkinis
« Reply #39 on: June 26, 2020, 13:28:41 »
About a year ago I noticed that theses spark plugs were becoming increasingly difficult to find, both in France and South Africa. It didn't seem to make sense.
I had a sneaky feeling that at some point they were going to discontinue these plugs.  So I bought a dozen of the BP5ES for my 280SL Pagoda which lives in France and dozen of the  BP6EFS for my R107 300SL which lives in South Africa.
Based on Dan's numbers above that should be enough spark plugs to outlive me.....
« Last Edit: June 26, 2020, 13:49:21 by Mike K »
Feb. 1971 Mercedes 280SL Auto  LHD (Last of W113 Series)
Aug. 1989 Mercedes R107 300SL RHD (Last of R107 Series)
http://michali.zenfolio.com
http://www.lebombo-safaris.com
« Reply #40 on: June 26, 2020, 17:48:16 »
My guess is good old standby Bosch and Champion have non-resistor plugs that will work.
« Reply #41 on: June 26, 2020, 18:17:28 »
I won't use Champion spark plugs on an aluminum head engine. Both Bosch and NGK use nickel-plated shells which tend not to seize in aluminum. Use whatever you want but be careful with what you use.
1988 560SEC
« Reply #42 on: June 27, 2020, 18:59:56 »
Champion plugs today feature what they call "TinTac® and ULTRASEAL" and they claim "eliminates the need for use of anti-seize compound by providing the best corrosion protection of any spark plug"
I'm not here to sell them [Champion] or to test them; I have a lifetime supply of NGK.
If you ever screw anything in, that eventually must come out, particularly with dissimilar metals, I'm a fan of anti-seize. I generally use light coatings of "silver grade".
« Reply #43 on: June 28, 2020, 08:53:10 »
i just renewed my stock of W7DC and had no problem buying 100 of them from my usual supplier.
WRe
« Reply #44 on: June 28, 2020, 09:05:45 »
I second Dan's statement about Champion spark plugs. I've used them for years and 30.000km and had problems with my new NGKs because of "altered" threads. It was hard to screw the NGKs in.
...WRe
merrill
« Reply #45 on: June 29, 2020, 19:42:57 »
hello
NAPA has the NGK 7333 BP6ES on the shelf
Bosch W7DC are available from K&K and Authentic classics as well as other suppliers
I ended up buying 6 ngk from Napa and 12 w7dc from a vw supply house.
At the rate i drive i now have a lifetime supply of these plugs.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #46 on: June 30, 2020, 13:10:26 »
Merrill, it depends on where you are! Here in NC, they are about wiped out (NAPA) of the NGKs. One local place had none; another had 5. I ended up buying sets at O'Reilly and Advanced. Of course AlexD and his pals in the Raleigh-Durham area wiped out the NAPA supply...
...and like many others I now have 18 BP5ES "in stock", as well as a set of BP6ES.
col320ce
« Reply #47 on: July 01, 2020, 13:01:32 »
There are still plenty available in Australia ... if anyone needs pointing in the right direction let me know.
Col
1964 230SL
1965 250SE coupe
WRe
« Reply #48 on: July 01, 2020, 14:44:23 »
in the meantime I believe that this story "to stop the production of non-resistor plugs" was launched by NGK to push their spark plug sales. ;-)
...WRe
« Reply #49 on: July 01, 2020, 15:43:30 »
...WRe
Haha. Remember, that all the plugs we've purchased, as far as NGK has been concerned, were already sold. Whether they sit on the shelf at NAPA or Advanced, or O'Reilly--doesn't matter. These retailers already bought and paid for them. We're just reducing inventory.
merrill
« Reply #50 on: July 02, 2020, 21:13:42 »
so to continue this discussion,
I had ordered x2 w7dc from K&K MFG.
Their website showed W7DC's available so i ordered 2 to complete a set (I had 4)
what showed up were W R 7DC+.   I called and talked to Steve the sales guy, he said he had to check on this and get back to me.
turns out Bosh had substituted the WR's and that was all they had on the shelf. They didn't even realize it.
on top of that before he called me back he said he talked to their supplier and they said the "R" doesn't make a difference.
i had to explain to him how the resistance affects the traditional ignition system and that they should at least update their website to reflect that they only carry the "new"  plug.
in the end i will get a refund on the 2 he sent me and i have already found more of the correct W7DC 7500's.
lesson learned to call first before ordering
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
« Reply #51 on: July 11, 2020, 19:28:14 »
i was in advanced auto parts today and just for fun asked the counter guy to check if they had any ngk 7333
in the Austin area they have 100 available.
the plugs are not listed on their web site, since they have been discontinued you have to ask in store if they have them
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
