Author Topic: Jammed hatch cover on 1969 280SL  (Read 4279 times)
rutger kohler
  • New Zealand, Auckland, Auckland
« on: March 05, 2020, 07:26:55 »
Hi, I put my soft top away properly, about a week ago, but now the right hand side of the hatch cover won't release. The soft top was stowed properly and the release cable is not broken. Using a torch, I can see the cable is working against the spring, on the right hand side but it is not releasing the right hand catch.  I have tried to remove the large chrome cover in this area, which would allow me access, however there are two phillips screws that can't be removed without the hatch cover up.
I have looked at the technical manual but can't anthing that will help relause the right hand side.
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
Re: Jammed hatch cover on 1969 280SL
« Reply #1 on: March 05, 2020, 08:14:24 »
Rutger,
 Try having someone pressing down on the cover on the side not releasing whilst you pull the release lever.  That may release the catch if there is upward pressure from the soft top on the cover
1965 MB 230SL Auto RHD Lt Blue 334G, Top 350H, 213 Leather, Tourist Delivery.
1972 MB 280CE Auto RHD 906G Blue Grey
2005 MB A200.
2019 Izuzu DMax 4x4 with Slide-on camper.
2022 Volvo XC40 Twin Electric
« Reply #2 on: March 05, 2020, 09:12:32 »
Yes, as Garry describes, I had a similar thing, it was the question of adjustment once it was open - too much slack on the cable. Pull the lever while someone is pressing the right hand side of the hatch. press where the leather is to avoid the dent on aluminum surface.
mbzse
« Reply #3 on: March 05, 2020, 12:23:17 »
In the Forum Technical Manual, under section "Top/Soft Top" there are some tips and pictures under a heading: "What if your release handle does nothing anymore?"
Also some tips in this thread:
https://www.sl113.org/forums/index.php?topic=16952.msg178065#msg178065
« Last Edit: March 05, 2020, 12:35:34 by mbzse »
/Hans S
rutger kohler
« Reply #4 on: March 06, 2020, 20:19:27 »
Hi, thanks for the suggestions, I have tried having someone pushing down on the right hand side of the hatch cover, as the release lever is moved, but alas, this doesn't work. There is absolutely no give on the right hand side,
It's frustrating because, with a torch, I can look down throgh the slots in the large chrome fitting and see the cable working against the spring on it, on the right hand side.
1972 280SE 3.5 auto
rutger kohler
« Reply #5 on: March 07, 2020, 06:37:31 »
A photo of the right hand side with the hatch open, showing the catch arrangement would be really handy
1972 280SE 3.5 auto
« Reply #6 on: March 07, 2020, 08:50:11 »
Is it not the photo within the link mbzse provided that you need?
« Reply #7 on: March 07, 2020, 09:42:56 »
I think this is the ones from Alfred’s post.
2005 MB A200.
johnm
  • Canada, NS, Lawrencetown
« Reply #8 on: March 07, 2020, 14:00:30 »
 unfortunately had this same issue and had to cut a small hole in the sheet metal to enable us to access the release. Once done and the latch adjusted the hole was easily patched (welded) and of course would never be seen once the carpet/upholstery was in place. Nonetheless a frustrating encounter.  Good luck?
1966 250S
« Reply #9 on: March 07, 2020, 14:41:21 »
It is possible to get a "L" shaped tool down into the hinge area and release the latch without cutting any holes. I'll try to post some photos.
mbzse
« Reply #10 on: March 07, 2020, 15:17:53 »
Quote from: ja17
It is possible to get a "L" shaped tool down into the hinge area and release the latch without cutting any holes../..
Some pictures and info here (courtesy of Wolfgang):
http://w113.eu/geschlossen/Optimierungen/Notoeffnung%20Verdeckkasten%20Mercedes%20Pagode%20W%20113.htm
A short film clip here:
http://w113.eu/geschlossen/Optimierungen/schnapper2.avi
(Emergency opening in seconds. I always carry this tool/handle in my SL, for me or for benefit of SL buddies)
/hans
« Last Edit: March 07, 2020, 15:24:08 by mbzse »
/Hans S
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #11 on: March 07, 2020, 16:05:28 »
Thanks for posting that Hans👍  That's a great little tool.  I'm off to Home Depot 😜
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
johnm
« Reply #12 on: March 07, 2020, 16:59:42 »
 Wow. wish I had thought of that. Excellent!
1966 250S
Norm
  • USA, TX, Wimberley
« Reply #13 on: March 07, 2020, 17:25:54 »
Can someone post what that tool would be called and where one might purchase?
Norm
Norm
1966 230SL 162H Blue-Grey
1994 Acura NSX Formula Red
2024 Acura RDX A-Spec, White Pearl
2016 Mercedes S63 AMG Coupe Obsidian Black
2011 Harley Davidson Super Glide Light / Dark Root Beer
« Reply #14 on: March 07, 2020, 18:09:57 »
This happened to me once before a few years back, and there was a post I made about this.
The CAUSE was a nut had come off the shaft, thus not allowing the shaft to turn or engage the release.
The SOLUTION was a 5 minute job at my friendly local (well, they are not so local any longer >sigh<) independent, Motorwerks in Commerce Township, Michigan. They got a piece of old brake line, (probably off some Porsche) bent it to form a J-hook, inserted into the compartment from the trunk (boot) where the hinges are, and pulled the release.
Voila. Done.
Once released, they affixed the nut back with Loctite, maybe a new lockwasher and said "It will NEVER come off by itself again".
2022 Ford Escape Hybrid
mrfatboy
    • Mrfatboy
« Reply #15 on: March 07, 2020, 19:03:34 »
Well that was simple and quick. 🤣  I had the parts in my garage.  Added an old gear shift knob for style points🤣
PN 113-1337-7001 🤣
Signal Red
4 Speed
« Reply #16 on: March 07, 2020, 20:07:26 »
Well done Mr. Fat Boy!  I admire the style points. A 10 from me, but the Russian judge is just an 8... ;)
FGN59
  • France, Provence-Alpes-Côte d'Azur, Marseille
« Reply #17 on: March 07, 2020, 21:28:12 »
We have a French saying: ‘la critique est aisée, l’art est difficile’, which loosely translated means: ‘reviewing is easy, art not so much’. So let me put my reviewer persona on, and criticize >:( (it is not just the Russian judges who are difficult):
A Swede ;) has sent you a picture of a German :) tool, which appears to be bent, obviously on purpose, with precise measurements. And with your typical Yankee ingenuity, gung-ho attitude, and flair for cutting corners, you come up with a straight tool  ???.
So the old world heritage in my French blood ;D feels forced to cry out: don’t you think the Germans, with their obsessive preciseness and efficiency, put in that bend for a reason?  8)
François
1994 Toyota Land Cruiser SW HDJ80 4.2L diesel
sold:
1969 280SL US specs, 4-speed manual, beige-grey (726H), parchment leather
1962 Jaguar MK2 3.8L (4.2L XJ6 engine), black, tan leather interior
1968 Peugeot 204 roadster, white, black interior
1955 Massey Ferguson TEF20 diesel tractor 😁
mrfatboy
    • Mrfatboy
« Reply #18 on: March 07, 2020, 21:32:56 »
I was going to put the bend in it.  However,  when I tested it without the bend it worked perfectly 🤣
I guess Yankee ingenuity works👍👍👍😜
Signal Red
4 Speed
FGN59
« Reply #19 on: March 07, 2020, 21:37:31 »
I have to say, I am utterly convinced! But we still have cheeses, bratwurst and Swedish meatballs.
François
sold:
Tyler S
  • USA, CA, Encinitas
« Reply #20 on: March 07, 2020, 21:38:12 »
Not to mention the German tool is only good for one (right) side. The first photo shows the demonstration on the left side with the compartment open. The area in which it sits would not be accessible with the hatch closed.
 So one straight tool? Or two bent tools that mirror each other?
My Hazet exhaust donut tool works well for this.
FGN59
« Reply #21 on: March 07, 2020, 21:40:46 »
Let’s not underestimate the Germans... maybe the mystery will be revealed one day  ;D
François
sold:
« Reply #22 on: March 07, 2020, 22:46:43 »
a being Aussie blunt, a sledge hammer would have fixed it straight away. None of this fancy German high tech, American ingenuity or French delicate touches.
After all no one said they wanted to save the car, Rutger just said he wanted to get the hatch cover open.
2005 MB A200.
FGN59
« Reply #23 on: March 07, 2020, 22:50:17 »
It’s been a long time since I last burst out laughing so loud. Thank you for that!  8)
François
sold:
mrfatboy
    • Mrfatboy
« Reply #24 on: March 07, 2020, 22:52:50 »
I think this thread is about a bunch of old tools 🤣🤣🤣🤣🤣🤣🤣🤣
Signal Red
4 Speed
« Reply #25 on: March 07, 2020, 23:09:42 »
The problem is that (most) Yankees have no language skills or the desire to learn one. The German fellow who came up with this tool was quite explicit in his description:"Der Knick bringt nur wenig Vorteile, daher ist er nicht notwendig" = the bent has little advantage and is therefore not necessary.
Along comes an ingenious yankee and thinks he reinvented the wheel, or the perhaps the can opener. 🙄  🤣 🤣
Sorry Tyler, even with the bent the tool works on both sides. But as the fellow wrote, the bent is not necessary, so your tool should work fine.
But as he also warned, if you haven't tried it on an open hatch where you can see the mechanism on both sides you will have to fiddle around for some time to open the hatch the first time you use the tool.
Tyler S
« Reply #26 on: March 07, 2020, 23:31:25 »
So it would seem...Its not really about the tool at all.. but the German or Yankee manipulating it. 😉
FGN59
« Reply #27 on: March 08, 2020, 07:36:01 »
Well, it seems that Mr Fat Boy (pardon the familiarity, this forum does this to me) had it right, it’s all about old .ools (sadly, for which one of us wouldn’t want to be a bit .ounger?)  8)
François
sold:
« Reply #28 on: March 08, 2020, 11:18:27 »
The guy who did mine some years ago didn’t fiddle with anything. He was an experienced body guy who saw the problem grabbed some scrap, fashioned a tool, pulled the latch, and solved the problem. As it was shown to me the hook on it was absolutely necessary in my particular case. After he did this the tool was tossed in the trash; after all it was just a piece of old brake line. This did not present any problem to him; the real issue was ensuring it didn’t happen again.
rutger kohler
« Reply #29 on: March 09, 2020, 06:30:19 »
Hi, just like to thanks all those who responded to my problem. I made the tool as shown by our German friends, however I was trying to pull upwards, on the tool. it finally dawned on me that I should be pressing downwards, and hey presto the hatch cover released.
1972 280SE 3.5 auto
