Author Topic: 1 3/4” AC Drain Hose Skirted Grommet  (Read 11263 times)
rbouch8828
  • USA, MA, Framingham
  • 280SL Mfg date AUG 1969
« on: February 12, 2020, 20:05:00 »
I have searched the Internet, but cannot find any source for a replacement of the original 1 3/4” AC Drain Hose Grommet that goes through the passenger side floor in the front right corner.
Has anyone found a source for these?
Roland
RB
WRe
Re: 1 3/4” AC Drain Hose Skirted Grommet
« Reply #1 on: February 13, 2020, 08:47:23 »
I assume you are looking for this grommet, see att. picture.
I couldn't find any part number or other details, sorry.
I would look for a "universal" grommet in a hardware store. What's the size of the hole and hose?
...WRe
doitwright
  • USA, IL, Willowbrook
« Reply #2 on: February 13, 2020, 10:07:21 »
None of the components used in the dealer installed AC systems have Mercedes part numbers. The units were manufactured in Texas.
Frank Koronkiewicz
Willowbrook, Illinois
« Reply #3 on: February 13, 2020, 10:54:29 »
I see several sections of drawings and parts lists for Jork and for Frigiking with Mercedes part numbers in the EPC... Maybe these are different types than those from the US.
I could not find the grommet you asked for though... Found the hose that goes through it, but not the grommet itself.
rbouch8828
« Reply #4 on: February 13, 2020, 12:07:30 »
...WRe
The hole is 1 3/4”. There isn’t a dimension given in our manual for the hose. I’d like to find that out too if someone has that info.
RB
450sl
« Reply #5 on: February 13, 2020, 17:07:17 »
I used a  1/2'' hose
rbouch8828
« Reply #6 on: February 13, 2020, 18:46:17 »
I used a  1/2'' hose
Was that a 1/2” ID or OD?
If it is 1/2” OD, then the hole they made at 1 3/4” in the floor seems pretty excessive.
Roland
RB
450sl
« Reply #7 on: February 13, 2020, 21:41:01 »
OD but with a thin wall. I used a small  universal grommet to keep as close as I could to position the hose out of the way as far as possibly.
« Reply #8 on: February 13, 2020, 23:43:14 »
Keep in mind that MB has never made their own AC units. They used York, GM, Nippendenso, and maybe others so they made their builds adapt to the AC pump.
rbouch8828
« Reply #9 on: February 14, 2020, 01:04:27 »
Hi Dr Benz,
We are only discussing the evaporator drain hose (Frigiking) grommet in this discussion. I’m trying to find out where I might be able to get a replacement for the 1 3/4” “Skirted Grommet” that goes through the floor in the front right corner of the passenger foot well. It is where the drain hose for the output of condensation from the Frigiking evaporator goes to the street.
I’d also like to know the correct size for the drain hose, ID and OD.
Roland
I’m trying to find
RB
« Reply #10 on: February 14, 2020, 04:06:03 »
Hi Dr Benz,
Roland
I’m trying to find
I know that. Most of the early cars used York compressors and were dealer installed. Most of those installs were done in NA so I would be looking for something from other NA cars built during the same time period.
« Reply #11 on: February 14, 2020, 07:03:51 »
For what it is worth, just to make this thread complete, this is the MB part number for this drain hose and SA codes:
A 113 835 06 97 | HOSE
55706   FRIGIKING AIR CONDITIONER
55706/08   U.S.AND CANADIAN VERSION
It is NLA, but if you try, they may offer replacement.
doitwright
« Reply #13 on: February 14, 2020, 07:59:33 »
Solution is simple.
Measure evaporator core drain hose attachment.
Select appropriate size hose.
Measure hose OD
Find appropriate grommet
Drill appropriate hole in floor.
Frank Koronkiewicz
rbouch8828
« Reply #14 on: February 14, 2020, 13:49:34 »
Solution is simple.
Measure hose OD
I have been unable to find a “Skirted” Grommet. There are plenty of 1 3/4” grommets, but I can’t find any “Skirted” 1 3/4” grommets.
Roland
RB
WRe
« Reply #15 on: February 14, 2020, 14:37:54 »
Sorry but I don't know what a "skirted" grommet is, maybe like this: https://www.oldtimerbedarf.de/gummi_5 ?
...WRe
rbouch8828
« Reply #16 on: February 14, 2020, 15:01:58 »
...WRe
No, it has a long extension below the opening at the top, like a “skirt”. So, it sits in the hole and looks like a normal grommet from the outside, but it is like a tunnel continuing the opening hole down for a specified length.
In the case of the drain hose, it protects the drain hose from chafing against the chassis metal as it passes through the Skirted grommet on the way to below the chassis for discharge of the condensation water.
« Last Edit: February 14, 2020, 15:11:03 by rbouch8828 »
RB
450sl
« Reply #17 on: February 14, 2020, 15:06:31 »
kind of like the waterdrain grommet used in the trunk of   the W107
Tyler S
  • USA, CA, Encinitas
« Reply #18 on: February 14, 2020, 15:16:00 »
A similar “skirted” drain grommet is used in the soft top compartment. Not sure on the size though.
rbouch8828
« Reply #19 on: February 14, 2020, 15:24:21 »
Wow! That one has a really long skirt!
The one for the drain hose is much shorter.
Do you have any source info for that one?
Roland
RB
Tyler S
« Reply #20 on: February 14, 2020, 15:33:56 »
Yes its long. It passes through the inner fender well on its way to the rocker panel. It is part number 1137790078. The photo below is from elsewhere on this site. My hardtop is installed so I cant get a diameter measurement.
The usual vendors have listings. Google the part number for options.
Here is one listing.
https://www.authenticclassics.com/Top-Case-Drain-Tube-Mercedes-230SL-250SL-280SL-p/auth-006296.htm
WRe
« Reply #21 on: February 14, 2020, 17:26:03 »
Ok, I understand a "sleeved" grommet but it will be hard to find it with 1 3/4" size.
I don't understand why it must have a skirt/sleeve because the drain hose is a skirt/sleeve itself. The hose needs only a protection for the metal hole means a simple grommet.
...WRe
« Last Edit: February 14, 2020, 17:36:15 by WRe »
rbouch8828
« Reply #22 on: February 14, 2020, 17:47:27 »
...WRe
I am just trying to replicate what was there originally. The Skirted grommet neatly dresses the edge of the carpet where it is cut for the hole to pass the drain hose.
Roland
RB
« Reply #23 on: February 20, 2020, 15:32:22 »
According to the install manual in our own technical manual the hole should be 1-3/8” not 1-3/4”. (I am in the process of drilling mine right now)  If the hole is 1-3/8” this is the grommet for it.  MB# 113 997 00 81
doitwright
« Reply #24 on: February 20, 2020, 17:28:03 »
The photo looks similar to the firewall grommet for the heater pipes.
Frank Koronkiewicz
