Become a
Full Member
Emergency Contact List
pivot rod bushing question
Topic: pivot rod bushing question (Read 2377 times)
merrill
Full Member
Platinum
USA, TX, Austin
June 29, 2019, 22:29:38 »
hello, quick question
for the pivot rod
are the steel bushings that go over the rod and in side the bronze bushings supposed to move freely on the pivot rod?
mine move freely in the bronze bushing but do not move on the pivot rod
thanks in advance
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
Full Member
Platinum
USA, TX, Austin
Re: pivot rod bushing question
June 29, 2019, 22:54:03 »
after doing some digging i found a post from Dan "benz Dr."
https://www.sl113.org/forums/index.php?topic=28214.msg203607#msg203607
The steel bushings are supposed to easily slide into the brass bushings and just barely slide over the tube that holds everything together.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
