Author Topic: spark plug wire guide tube question  (Read 3068 times)
merrill
« on: May 27, 2019, 17:02:48 »
hello
this may be a 2 part question
I purchased a spark plug wire guide tube bracket for my car,  the wires run inside the tube and then come out the bottom  see photo
question is should i be able to run the wires in the tube with out removing the ends.  I am talking about the 90 deg end that plugs into the distributor cap
if not,  how can i remove an end of the spark plug wire to be able to run the wire in the tube and then re connect the end.
i may be over cautious here.
thanks in advance matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
PeterPortugal
  • Portugal, Faro, Lagoa
Re: spark plug wire guide tube question
« Reply #1 on: May 27, 2019, 21:36:40 »
Hi Matt,
I think you should not have the plug leads with 90 degree ends if your car uses this kind of guide.
I recently fitted new plug leads with straight ends and they were simple to push through.
1963 220se Cabrio
1968 280se Coupe
« Reply #2 on: May 28, 2019, 05:26:52 »
One or both ends should unscrew.
