W113 Pagoda SL Group > Wanted To Buy
unknown fuel part
(1/1)
jpressick:
My 1967 250sl is leaking gas near the front of the gas tank. The leak is coming from a part that is attached to the floor of the trunk and has three fuel pipes going into it and is separate from the gas tank. I have taken the part out and apart which contains a spring about 5 inches long and 1 inch in diameter. I don't know the name of the part but know the gasket is leaking. I am trying to identify the part so a new gasket can be ordered. Any help would be appreciated.
Benz Dr.:
That sounds like it's the brake force regulator. Your leak would be brake fluid.
ja17:
Yes, sounds like a brake valve.
Shvegel:
If you took your brake force regulator apart you might want to consider sending it off to be rebuilt. Brake parts fail when you need them the most. I am pretty sure these guys rebuild them.
https://www.pmbperformance.com/brake-calipers.html
Navigation
[0] Message Index
Go to full version
