W113 Pagoda SL Group > Wanted To Buy
WTB Gas Pedal Linkage - FOUND -
(1/1)
johnbrowder:
As part of an engine swap project my prior mechanic installed a nonstock pedal assembly out of a later model C-class. I want to go back to the original w113 setup. All of my OEM parts are gone, so I need everything from the pedal on. I will need to convert to a cable somewhere at the firewall to mate with the w124 engine. Thanks!
johnbrowder:
Found what I needed at Bud's in Atlanta. Thanks for looking.
m300cab:
ok, good luck
the 280se 6 cylinder is pretty much the same as the 280sl
Navigation
[0] Message Index
Go to full version
