Author Topic: Rubber Sleeve for Breather and Water pipe  (Read 7749 times)
RobSirg
« on: February 05, 2019, 04:03:47 »
Hi All,
I'm looking for a shorter version of the protective rubber sleeve covering the breather tube and water pipe in the engine bay. I previously purchased this item with a 'rib' in (see photo's) so you could trim it down to the length you needed, however, the main suppliers these days seem to only sell it in the longer length without the rib.
Any information of where I can source the shorter version, or the version with the rib? (as shown attached).
Thanks in advance
Rob
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Rubber Sleeve for Breather and Water pipe
« Reply #1 on: February 05, 2019, 12:20:46 »
I have read on this forum that only the long version is available.  Maybe that has changed and someone will chime in.
Otherwise, people cut it while leaving a little extra and rolling it back on itself to simulate the rib.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
UJJ
  • USA, CA, Grass Valley
« Reply #2 on: February 05, 2019, 14:53:33 »
I am in need of this part as well.
How do you roll it back, it is pretty rigid?
Urban
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
mrfatboy
    • Mrfatboy
« Reply #3 on: February 05, 2019, 16:13:56 »
I replaced mine last year. My car required the long version so I didn't have to do the "roll back".
I was concerned also about getting the rubber sleeve over both pipes without breaking/ripping it.  It is durable and has much more "give" in it than I thought.
When researching how to do it I read on this forum that a couple of guys did the "roll back" method for their later cars. I don't think they gave specific instructions other than what I already stated.
I used McGuire's Hot Tire Spray as a lubricant to slide the sleeve on.
Signal Red
4 Speed
RobSirg
« Reply #4 on: February 05, 2019, 20:37:11 »
It rolls back easy enough - it’s what l have done now but doesn’t look at all good. Not something l can accept.
I have one option l am trying to avoid - swap the one that is on one of my earlier cars over and hope it doesn’t break in the process.
The one you see in the photo was taken off an old set of pipes - but it was so rigid it broke apart ( not seen in photo).
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #5 on: February 08, 2019, 11:13:57 »
Rob
What is the part # on your tube?
I believe the shorter one is 007 997 7782
https://www.theslshop.com/mercedes-benz-m114-m130-engine-rubber-breather-hose-0079977782.html
RobSirg
« Reply #6 on: February 09, 2019, 07:06:04 »
Thanks Naj,
I will follow this lead. I might just ask the SL Shop for the dimensions to make sure.
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
RobSirg
« Reply #8 on: February 12, 2019, 04:11:45 »
Hi Naj,
I just checked the part number of the broken one I photographed (longer version with the rib) and it is indeed 0079977782.
If Mercedes still make it with rib then it will be fine - but it seems our usual suppliers are selling a version without the rib. Not sure if they are selling after-market or if Mercedes changed suppliers?
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #9 on: February 12, 2019, 12:03:14 »
When you buy Mercedes it is the long one with rib, star logo and the part number.
« Reply #10 on: February 21, 2019, 23:39:42 »
I just tackeled this on my car.  I cut the sleeve cleanly where needed with a very shap knife.  I then trimmed the remainder within 1/2”(13mm) of the bead on the end. I then stretched the bead over a large rod (I used a socket) and trimmed right next to the edge bead with a razor blade.  Then I crazy glued the edges together.  I might smear a tiny bit of black urethane caulk in the groove to make it cleaner.
mrfatboy
    • Mrfatboy
« Reply #11 on: February 21, 2019, 23:42:59 »
Nice work a round👍
Signal Red
4 Speed
« Reply #12 on: February 22, 2019, 07:04:25 »
I think you got brilliant result!
I just re-applied the "terminal rib" back after carefully cuting it - it is less permanent and does not look as good as yours...
RobSirg
« Reply #13 on: March 11, 2019, 23:26:07 »
So today I received the original part from Mercedes USA and...…..drum roll...….it has only one rib :'(
I guess I have no choice now but to slice it down to size myself and reglue it.
Who knows I probably did buy the original part in the first instance.
Case closed.
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #14 on: March 13, 2019, 01:01:21 »
That's a bummer.  I am not a huge fan of cyanoacrylate (crazy)glue.  But one area it really shines is gluing rubber.  I have fabricated tons of o-rings from round stock as large as 8mm and they always seem to hold.
mmizesko
  • USA, OH, New Albany
« Reply #15 on: March 13, 2019, 15:19:28 »
Joe Alexander and I sourced the correct Breather Pipe Tube Sleeve a couple of years back and it was correct for my 1970 280SL.
Part number was : 007 997 7782
Fit nicely.
Best regards,
Mike Mizesko
1970 280SL 291H Dark Olive
cfm65@me.com
  • Cape Town, South Africa
« Reply #16 on: March 13, 2019, 18:16:44 »
Well done Shvegal
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #17 on: March 13, 2019, 23:43:59 »
Fit nicely.
Best regards,
Mike Mizesko
Yes, this is what I ordered December 2017 and I got the long one. Had to cut.
RobSirg
« Reply #18 on: March 14, 2019, 13:41:53 »
Same part number I ordered.
Will try "crazy" glue. I am guessing that is "superglue" in Oz?
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
