Author Topic: Not sure this is correct  (Read 3769 times)
CJHenderson
  • USA, AR, Benton
« on: August 17, 2018, 21:43:28 »
Looking in the left rear wheel well and see this patch. Does not look like it belongs there.
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Re: Not sure this is correct
« Reply #1 on: August 17, 2018, 22:32:29 »
Quote
Absolutely incorrect for any Euro-280 or other rest-of-the-world-280. :-X
But correct for a US-version 280 from model year 1969 (??) onwards. ??? 8)
The lines from the expansion tank (running between the fuel fumes overflow tank and the crankcase) are protected by this shield.
Achim[/size]
CJHenderson
  • USA, AR, Benton
« Reply #2 on: August 18, 2018, 23:01:55 »
Ok thanks.
1950 MG-TD
« Reply #3 on: August 20, 2018, 12:37:46 »
Your’s looks much nicer than mine.  I need to make a new one.
« Reply #4 on: August 22, 2018, 16:00:48 »
70 and on. USA only.  Anyone know what the correct original color is?
« Reply #5 on: August 22, 2018, 20:59:26 »
It would be painted the color of the car, just as the wheel wells.
« Reply #6 on: August 22, 2018, 23:10:29 »
I've seen them painted and then I've seen them black. Looks like they're installed after the car is painted.
« Reply #7 on: August 23, 2018, 00:26:40 »
Car color with yellow chromate screws?There is no overspray on the plastic hoses that go under the cover I would assume it is installed later.  Surprised it isn’t stamped with the chassis number.
