Author Topic: Cylinder heads, alternatives???  (Read 9195 times)
Malc
« on: January 18, 2005, 08:45:56 »
Maybe somebody knows...
Is there a more modern MB head that will fit a 230 engine, for example a 24v one..
Ask because I know you can do this with BMW 6 cylinder engines as the block and bottom end has basically remained the same for years
Just a thought
Malc
Re: Cylinder heads, alternatives???
« Reply #1 on: January 18, 2005, 09:17:21 »
Hi Malc - I very much doubt it. In fact, there are two versions of the 280 SL's M130 engine block + cylinder head (oval and square combustion chambers) that don't even match!
« Last Edit: January 18, 2005, 09:18:07 by cees klumper »
Malc
« Reply #2 on: January 18, 2005, 10:29:56 »
Dang!
Thanks Cees, just trying to think of alternatives
Malc
« Reply #3 on: January 18, 2005, 10:31:15 »
Yes but that later 280 engine came out very late in production, for no apparant reason, it didn't offer more power and the original style didn't give any trouble either!
Is it possible the MB used this later blok for the 280 twin cam engine in the W116/W107 ? Actually even this engine did not put out much more HP anyway I'm probably wrong !
« Reply #4 on: January 18, 2005, 11:21:12 »
You can exchange the 230 and 250 heads. The parts inside the heads are different but even that can be modified to work.
Daniel G Caron
« Reply #5 on: January 18, 2005, 21:10:36 »
Hello Guys,
There are four common types of 113 heads. The 230-SL, 250-SL. early 280-SL, and late 280-SL. The 230-SL and 250-SL are interchangeble as stated. The others cannot be switched. And the 230/250 heads cannot be used on any 280 or visa versa.
The 230-Sl head is unique to that W113 model (not used on any sedan engines). The 250-SL, 280-SL (early) and 280-SL (late) heads  can be found on their respective 250-SE, 280-SE sedans, coupes and convertibles of that era.
The 250SL/SE head when used on a 230-SL engine will enhance performance slightly with it's larger valves. The design of the 250 head is a little more modern and has features not found on some of the 230-SL heads such as valve rotators, larger valves, newer design of the valve guides and seals.
There were minor design changes during the run of each of these series so head casting numbers may vary from year to year. For instance there may be three or four different head numbers in the 230-SL series all which are interchangable.
The 230-SL head I have has no model designation cast into it just the head #127 016 1901 with 9.3:1 compression. This number is located between the 2nd and 3rd spark plug. The year of manufacture is "65" cast into the top deck of the head.
The 250-SL, SE head I have is identified "250" with #129 016 0301 with 9.5:1 compression. The year of manufacture is "66" also cast into top deck of head.
The early 280-SL head I have is identified as "280" with #130 016 0701 with 9.5:1 compression ratio. The year of manufacture is no longer cast in the top deck.
The late 280-SL head I have is identified as "280-SE/A" with #130 016 0801 also with 9.5:1 compression. I have heard that the "A" in this designation signifies that it was for USA delivery cars?
There are some other less common variations like the low compression engines, used mainly in underdeveloped countries.
In addition these cast numbers on the heads may vary slightly from minor changes in design during production. For example; I also have an earlier 230-SL head "64" #127 010 4220 also with 9.3:1 compression. This "64" 230-SL head number is different from the 230-SL head listed above. This was a result of minor design changes during the series. These heads are interchangeable and are basically the same as all other 230-SL heads.  I believe there are one or two other numbers within this group as well.
For interchanging, think of three posssible head types first: the 230-SL, 250-SL(interchangeble), second: the early 280-SL, and third: the late 280-SL. These three are unique and must be kept with their engine blocks.
Ben,
The twincam engine M110 had a block remarkably close to the M130(late). I am not sure if it could be used in place of a late M130 block? I believe the crankshaft may be the same.
These M110 (twincam) engines were supposed to be  much improved over the M130 (280-SL) with it's cross-flow hemisperical combustion chambers and twin camshafts. In reality only a  small amount of horsepower was gained and the M110 engine ended up being extremely heavy and complex in comparison to the earlier six.
The result was little or no noticable improvement in performance over the european delivery M130 (280-SL) engine. Mercedes quickly reverted back to a single camshft simpler, lighter  and more efficient  engine (M103) in the later 300E series W124 chasis cars.
1975 was the year of ruination for most Mercedes gasoline engines in the USA. Compression ratio had already droped from 9.5:1 to around 8:1 in 1973. The addition Catalytic comverters in 1975  along with a mess of emission devices really bogged down these engines. Steer clear of 1975 gasoline USA delivery Mercedes whenever possible. The horsepower of an emmision 1975 450-SL was only  175 hp! These changes became more integrated and less troublesome in  later years after 1975 and horsepower slowly crept back up as time went on and emission designs improved. The high compression, emission device free european delivery engines of 1975 era were noticably more powerful and less troublesome than the USA conterparts.
« Last Edit: January 18, 2005, 21:19:24 by ja17 »
« Reply #6 on: January 19, 2005, 00:16:06 »
The 230SL head is unique but not exactly as described.
The heads do have roto caps - or at least all the ones I've seen do. The valve spring retainers are special to that engine and are very exspensive - over $50.00 each. The keepers are square cut like what you'd find on a 190SL.
 I think these valves are the same size on the face as the 250SE but are a different size on the stem. The 250/280 exhaust valve stem is quite a bit larger in size while the intake is the same size. Valve stem seals set is also unique to the 230SL engine and quite a bit more than the later sets.
Strangest head I've ever done had to be a 220SE. No roto caps but it does have ball studs. The valve stem seals look like little doughnuts while the exhaust are rubber seal rings. Same valves as the 230 and 220Sb from which it was further developed in 1963 from the 220SEb engine as of 1961.
These engines were manifold injection but the blocks are very similar to the 230SL. Could likely be used - never tried.
Daniel G Caron
« Reply #7 on: January 19, 2005, 05:16:45 »
Hello Dan,
You are right on the roto caps both these 230-SL heads I have here do have them.
 On the sedan head; yes, it would bolt up to a 230-SL fine but there is no place to screw the injectors in, since as you know the injectors are in the intake manifold on the sedans. This acounts for the straight sided valve covers on these engines and the "snake-like" valve cover side on the six plunger injection pump  cars.
« Last Edit: January 19, 2005, 05:19:41 by ja17 »
« Reply #8 on: January 19, 2005, 16:08:02 »
Thanks Joe. I was referring to the block on the 220SEb - it may be the same or similar enough to be bored out to standard size for the 230SL early engine. Later engines used different pistons and conecting rods very similar to 250SL. The block and crank are the same though.
This was a  time of real development and a lot of these engines shared parts or were a transition from one idea to the next. Main engine casting are a good example. The 220 block is the same size as the 280 block with the cylinders being larger and closer together as displacement increased. The outer dementions for the block are the same so that the production machinery could be modified without changing to a whole new set up. Even back then they considered costs and how far they could develope the power units.
Daniel G Caron
