Author Topic: Getting ready to start pulling axels from rear.  (Read 2461 times)
CJHenderson
  • USA, AR, Benton
« on: May 17, 2018, 17:59:32 »
Is there any overhaul manual that is better then this useless Haynes manual that I got from AutoZone. Also can I pull the right axel housing without destroying the bellows?
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Re: Getting ready to start pulling axels from rear.
« Reply #1 on: May 17, 2018, 18:44:07 »
Is your axle still installed or is it out of your car?
CJHenderson
  • USA, AR, Benton
« Reply #2 on: May 17, 2018, 20:48:16 »
It's out sitting on the table
1950 MG-TD
mbzse
« Reply #3 on: May 17, 2018, 23:01:24 »
Quote from: CJHenderson
Is there any overhaul manual that is better then this useless Haynes manual.../...
Yes, certainly. The factory has produced lots of detailed technical literature.
Available for instance here:https://www.mercedes-benz-classic-store.com/en/literature-media/technical-literature/
You need the 1968 Workshop manual (often named BBB here in the Forum; "Service manual starting year of construction 1968, W 108 - 113").  "Book of Tables" (1971) is also much useful.
BTW, the Haynes has lots of confusing and inaccurate information. I suggest you use that book with some caution.
« Last Edit: May 18, 2018, 08:15:25 by mbzse »
/Hans S
jameshoward
« Reply #4 on: May 18, 2018, 00:13:40 »
I'd also suggest you do some serious reading up on the task on this site to. There's a ton of great info here from people who've been there before.
James Howard
1966 LHD 230SL
