Author Topic: 6 Speed conversion using Anna Thom Engineering Transmission  (Read 28467 times)
PagodaMafia
Hello, decided to spin up a fresh topic on my experience converting the terrible sluggish factory 4 spd to 6spd. The transmission from purchase from small boutique engineering firm in Poland that has been making a name for themselves in the European resto-modding scene.  Without out doubt the most rewarding modification. The transmission totally transforms the cars driveability and higher speed cruising, not to mention the acceleration and torque. iIt actually feels like proper sports car. Anyway will post up some pics of the conversion and videos if anybody is interest?
doitwright
  • USA, IL, Willowbrook
Re: 6 Speed conversion using Anna Thom Engineering Transmission
« Reply #1 on: March 24, 2018, 01:53:44 »
Of course we would like to see some pics.
Frank Koronkiewicz
Willowbrook, Illinois
Kevkeller
  • USA, HI, Honolulu
« Reply #2 on: March 26, 2018, 11:09:56 »
Yes please.  I’m in need of a new tranny sometime.
Thank you,
Kevin
1970 280 SL
six speed classic Gearbox
« Reply #3 on: March 26, 2018, 15:52:51 »
hi,
if you like to order one, please ride here k-max@live.de
thanks
tom
« Reply #4 on: March 26, 2018, 15:55:43 »
Kevkeller
  • USA, HI, Honolulu
« Reply #5 on: March 26, 2018, 17:50:36 »
What is the cost?  Are there modifications that need to be made or does it drop right in?  Does the company have to do the change out or can the owner do the work?
1970 280 SL
« Reply #6 on: March 26, 2018, 17:56:52 »
hi,
thanks
tom
In the Wanted to Buy forum you claimed that 312 of your transmissions are installed in Pagodas.
Thus, let me repeat my questions here:
Where are these Pagodas located? Can you provide some proof for your claims?
How many are driving around in the USA? Can one contact a few dozen of these 312 Pagoda owners and ask them how satisfied they are, what problems they encountered during installation (if any), any subsequent repairs, etc, etc. ?
Otherwise all your claims remain virtual and not substantive.
« Last Edit: March 26, 2018, 18:05:20 by 66andBlue »
PagodaMafia
« Reply #7 on: April 17, 2018, 13:54:21 »
Hi Gentleman sorry for my late response. My 3 month old daugther has been keeping me busy.  My little 280 sl is located in Sydney. My mechanic Alex is brillant had it installed in 2 days. That said the kit was professionally put together. I have  heaps of pics can some tell me if i am allowed to post links to google photos. The guys at anna tom are amazing... not at all "virtual" and extremely professional and properly engineered no parts bin antics. Ken if you want Skype i can go and visit Alex and you can ask him stuff. Again not sure if it is forum policy ??
PagodaMafia
« Reply #8 on: April 17, 2018, 14:03:31 »
See link i posted on offical w113 forum google group. https://plus.google.com/114683331210504169942/posts/TyY57Eo4Few
doitwright
« Reply #9 on: April 18, 2018, 14:07:45 »
I went to the photo link but only 4 pictures appear. The other photos are black screens. Your carpet shifter cutout indicates an automatic trans previously. Good to hear about your positive results.
Frank Koronkiewicz
PagodaMafia
« Reply #10 on: May 10, 2018, 22:32:06 »
Hi doitwright. Again family have been keeping me busy. Try to look at the pics again they are all on google drive and high res so if you on slower internet connection it might black out while it down loads
billhon
« Reply #11 on: September 03, 2018, 00:17:52 »
I agree with Frank. We need to establish some credibility on this tyranny conversion. If it's phenomenal then 100's will sell overnight. Thanks.
« Reply #12 on: September 03, 2018, 01:22:47 »
Unless there's a substantial gear ratio change in 1st, 2nd, and third gear, I'm having a difficult time imagining how the same car with all other parts being the same, can suddenly transform into a cafe racer just by changing the transmission. What's the final drive ratio in 6th gear?  And further to that, how is the MB 4 speed trans is sluggish? Are you referring to the auto trans - I could agree to that to some degree? You only have about 175 HP to work with so even on a good day, regardless of how you chop it up, you still have the same old salad.
 Mr. Mafia? What's the rear axle ratio in your car right now? This is where performance comes from and 5 or 6 speed transmissions change that final drive to higher axle ratios inside the trans. I would not go higher than 3.27 and only in a 280SL with a 4 speed gear box. If you can keep your final drive ratio at or above 3.27 then it should be OK. This would indicate to me that your six speed is a close ratio gear box in 5th and 6th gears, or that 5th is 1:1 and 6th is overdrive.
MikeSimon
  • USA, OH, North Royalton
« Reply #13 on: September 03, 2018, 14:44:03 »
I am with the Benz Dr, here on this subject. (probably because we are both naturally "Doubting Thomases"). An optimum transmission "tuning" is done together with the engine power curves.
Ideally, you would reach a "shift-up" point when engine rpm reaches the hp max point. After upshift, engine rpm ideally should drop to the max torque point.
This way, you will have optimum engine performance in every gear. Of course, you can add an "overdrive" with a ratio that allows you to just hold your speed somewhat, which means it will drop engine rpm to somewhere below max torque.
The "wider" the power band of the motor is, the less gears you would need. For a narrow power band, you need more gears. Considering that our Pagodas were originally designed when the emission and compliance bureaucrats in the governments weren't all that abundant, I think our cars are doing pretty well the way they are. But if somebody comes up with a set-up that will allow him to beat a Porsche GT3 on the track - more power to them (punt intended)! 8) 8)
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Jowe
« Reply #14 on: September 03, 2018, 17:53:32 »
I found this info, which I beleive is the tranny discussed: https://oldtimer-ersatzteile24.de/6-speed-gearbox-for-Mercedes-230SL-W113-Pagode
Johan
PagodaMafia
« Reply #15 on: March 27, 2019, 11:58:36 »
Jowe, that is definitely the transmission from Anna Thom.
« Reply #16 on: May 05, 2019, 17:27:18 »
I understand Benz Dr. comments.  I have a rebuilt stock manual transmission and 3,27 rear end.  They seem perfectly mated and I enjoy the car at in all gears.  I can see where some improvement could be had with closer gear ratio changes.  While my shift bushings are new the gear shifting experience is good for a 50 year old car. I can see where a more precise shift mechanism and closer gear ratios would be nice to have.  I like my setup and don't think I'll change my mind.
teahead
  • USA, WA, Des Moines
  • aka "Rob"
« Reply #17 on: June 24, 2019, 21:01:57 »
Any major modifications required?
Driveshaft shortening?
Tunnel enlargement?
Cutting/welding, etc.?
« Reply #18 on: June 24, 2019, 22:13:59 »
Drive shaft would very likely need to be shorter but maybe that's part of the kit.
« Last Edit: June 25, 2019, 04:19:31 by Benz Dr. »
Ibrahim
« Reply #19 on: October 07, 2019, 21:40:19 »
Great idea.  I am restoring a 1970 280SL.  I was looking into some transmission upgrade.  This seems to be what I am looking for.  Please provide us with the information about the firm that provides the 6 Speed conversion.
UJJ
  • USA, CA, Grass Valley
« Reply #20 on: October 08, 2019, 13:58:38 »
I am not opposing to upgrade to a 5 or 6 speed transmission, however, I modified my rear end to 3.27 about 10 years ago and I am very happy with that.
My 280 SL with the manual 4 speed and this rear end is not sluggish at all. At 3500 rpm I am cruising at 75 mph and if I need to accelerate to a higher speed, it really goes very rapidly to 80mph  or higher.
For me this is a perfect set up.
Best, Urban
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
teahead
  • aka "Rob"
« Reply #21 on: October 08, 2019, 16:44:48 »
Seems a 6-speed is overkill.
A Getrag 265 with a mechanical speedo would be WAY cheaper.
Even if you had to have it rebuilt by say...Metric Mechanic for $3200 USD, can get a good core for less than $800USD.
Fred Verboon
« Reply #22 on: November 22, 2020, 11:20:53 »
Are there people who have recently installed a modern gearbox (5 or 6 speed) And may I ask about your experiences?
And are there any modern low cost alternatives to the already described Getrag 265/5 gearbox?
I am looking forward to any tips / offers  :)
Kind regards, Fred
« Reply #23 on: November 22, 2020, 23:45:19 »
I thought the Getrag was the modern cheaper alternative. I fitted one and it was fantastic.
There is the ex President here, Ray Hays, who fitted a T5 Tremag i think it was called that may be the alternative.
« Reply #24 on: November 23, 2020, 14:47:40 »
...T5 Tremag...
Tremec, which used to be Borg-Warner.
https://en.wikipedia.org/wiki/Borg-Warner_T-5_transmission
https://www.tremec.com/menu/t-5/
There's a lot of different models and it's been a robust tranny made for decades.
