Author Topic: Taking apart Constant Speed Solenoid (CSS, Lift Magnet)  (Read 13798 times)
mnahon
  • Canada, QC, Montreal
« on: January 08, 2018, 00:54:02 »
I'm wondering if anyone here has taken apart a constant speed solenoid (CSS), also known as 'lift magnet'?
I have a CSS that half-works. When energized, it starts to extend, but then binds. My impression is that the shaft may be bent, so I'd like to take the CSS apart. However, there's no obvious way to do this. I was wondering if someone here has done this before and could give me some guidance. I could post pictures of where I'm at if anyone figures they have an idea.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
Re: Taking apart Constant Speed Solenoid (CSS, Lift Magnet)
« Reply #1 on: January 08, 2018, 13:17:15 »
Disassembly is possible but re-assembly is not!
« Reply #2 on: January 08, 2018, 15:30:33 »
Sounds very, very familar to me on a lot of fronts...
« Reply #3 on: January 08, 2018, 17:47:55 »
New these seem to list at over EUR 1,000 - but in Niemoiller's catalog it appears to refer to these as 'rebuildable' meaning you  have to pay them EUR 1,000 as well as return your old unit. I recall a long time ago a discussion on here where someone may have reported having succeeded in rebuilding one, but I am not sure.
« Reply #4 on: January 09, 2018, 02:38:35 »
See my post Dec. 23, 2016
I disassembled it, repaired it and it has worked since
Attached see pic of disassembled solenoid. There is a brass washer for a stop and I replaced it with a thicker one. Works fine now - no stickum. Current draw before modification 1.02 amp, after installing thicker washer 1.03 amp
« Last Edit: January 09, 2018, 02:49:25 by TheEngineer »
mnahon
« Reply #5 on: January 09, 2018, 04:25:39 »
This is encouraging! I found your Dec 23, 2016 post and read it through. I think my solenoid has a different problem than yours, but irrespective, disassembly is where I need help.
Here are some pictures showing where I'm at. In the first picture, I show an end view showing the only place where I thought there were options for disassembly: there are three set screws. Each set screw is restrained from unscrewing by two tabs. I managed to remove one set screw by using a Dremel to grind out the restraining tabs, and then unscrewing. But when I look into the hole, it's not clear to me what these setscrews do, nor what I may be able to do when I remove the two others.
But now, when I look at your picture, I realize that you attacked the other end; not the end with the set screws. So my third picture shows that end, and it's not clear to me how you got that end cap off. Any pointers? Thanks in advance.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
« Reply #6 on: January 09, 2018, 05:53:56 »
Going by memory: I put it into a lathe and cut the swaging. The screws hold the coil. Leave the screws in place. The plunger can not come out of the back, it is prevented by the nut. To replace the swaged cap I put aluminum adhesive tape over the opening.
cfm65@me.com
  • Cape Town, South Africa
« Reply #7 on: January 09, 2018, 11:59:00 »
IIRC Thierry du Laos also successfully opened and repaired his CSS, some time ago.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
mnahon
« Reply #8 on: January 09, 2018, 14:12:52 »
Thanks for the responses.
I've just sent Thierry a PM to see if he can join the thread. Depending on what he says, we can see if using a lathe is the only way in.
It may take me a bit of time to get access to a lathe.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
« Reply #9 on: January 09, 2018, 15:18:38 »
My guess is, as opposed to Niemoller or others, maybe a custom made solenoid might be less costly. Indeed, maybe some of these folks have built similar sized and powered units that can be adapted...
https://www.tlxtech.com
http://www.ccoils.com
http://www.guardian-electric.com/custom-applications.html
http://www.snmfg.com
cfm65@me.com
« Reply #10 on: January 09, 2018, 18:31:12 »
Meyer,
Thierry lives in Laos, but spends alot of time in France. You can look at his profile and see some photos and read up on what he wrote about the subject.
I am sure he will give his input when he sees your post.
Chris
Cape Town
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
mnahon
« Reply #11 on: January 10, 2018, 04:47:40 »
Michael, pragmatically you're right that there are probably some more effective, cheaper and practical options by adapting a modern off-the-shelf unit. But part of this is for the fun and challenge to see if I am able to repair the old one.
Chris, thanks for the pointer to Thierry's posts on this topic. Here is the link to that page:
https://www.sl113.org/forums/index.php?topic=25242.msg180704#msg180704
He also used a lathe to open the CSS, but he opened it from the other end (the end with the setscrews). Right now I'm thinking that TheEngineer's approach is less destructive, so I will likely follow that. Seeing the innards, I figure mine probably also just needs a cleaning inside. It does work; but it binds along the way.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
Thierry du Laos
« Reply #12 on: January 10, 2018, 05:35:10 »
Yes I rebuilt my CSS, but I coudn't open it.
It was glued (Probably Loctite thread inside) and I had to cut out the front (shaft side) to open.
Inside it was all rusted. I think because this solenoid is energized all the time and warms up. Then when you stop the engine, it brings condensention in.
So I used the lathe mandrin to hold the shaft and de-assembly/extract, cleaned inside and greased.
But I had to make a new part to put it back together, and replace the part I took/cut out to open, on my lathe.
I have some pix posted already, but for more, unfortunatly I just forgot my hard disk in France with all the pix!!!!
However if you need more, i can try to explain better?
Now I cannot find the PN, and where its available, of the 2 pressure switches installed on the gear box. Because when the CSS works well, it is allways energized. Even when the engine is not truning..... And the engine stalls when selecting the D or R, of course I need to adjust on a working system. Seems it's not available at Niemoeller!!
mnahon
« Reply #13 on: January 10, 2018, 14:44:15 »
Hi Thierry,
(post modified)
For me, the pictures in your thread are sufficient; I can see what you did and I don't need any more.
Regarding your problem: are you sure the switches on the transmission are at fault? As far as I know, the CSS should be at 12 V when the ignition is on and CSS connected (I think both wires should show 12V relative to ground). But when D or R is engaged, one of the wires gets grounded and that energizes the CSS.  There is a small wiring diagram in the BBB that shows this, shown in this thread:
https://www.sl113.org/forums/index.php?topic=23678.msg169338#msg169338
I'm saying all this because it's possible that in your reassembly of the CSS, you accidentally grounded something and that would then cause your CSS to be always energized.
« Last Edit: January 10, 2018, 15:42:08 by mnahon »
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
Thierry du Laos
« Reply #14 on: January 12, 2018, 07:37:55 »
Hi Meyer,
You are correct, I have to check better these wires.
I may do that this week end...
And on the link you just sent there is the wiring wich will help me: Automatic trans electrical wiring diagram #1.jpg
Never saw this one!
Because its not fun to crowl under the car to do this one!!!
Thanks, I'll keep you informed.
Thierry du Laos
« Reply #15 on: January 15, 2018, 07:55:46 »
Hi Meyer,
This weekend I tested the ground wire, but everything went correct! So I connected again the system to the fuse, and it works!
I wonder if I don't have a intermittent ground or if due to the cold weather and the parked fperiod the pressure switches didn't wake up?
However for the the time beeing I cannot trouble shoot again until the problem occurs again.
I like this anyway, its a fast repair and cheap too.....
Thanks to you for kicking me to try to fix it again.
Best
mnahon
« Reply #16 on: January 16, 2018, 04:46:13 »
Sounds like good news, at least for now. Let's hope it stays fixed.
Having spent a lot of time on British cars, this is often how a lot of repair happens---don't rush to fix it; often the problem goes away on its own. Especially on the electricals. It's probably what's turned me into a procrastinator.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
« Reply #17 on: January 13, 2019, 10:24:28 »
New one now available
A000 072 0500
« Reply #18 on: January 14, 2019, 15:20:33 »
Interesting Naj,
Brentford still say NLA
« Reply #19 on: January 14, 2019, 22:36:56 »
I checked. It is available, my dealer says they can order through Clasic Center. About EUR 900 without VAT.
But the Webparts says it is not available. But it is.
« Reply #20 on: January 15, 2019, 02:59:35 »
Hence the old saying "Never put off until tomorrow what you can do
the day after tomorrow"
« Reply #21 on: January 15, 2019, 03:28:06 »
Ha,  I have one just as good.
'' There's never time to do something right but there's always time to do it over again. ''
« Reply #22 on: January 15, 2019, 12:36:46 »
 :D
Good one Dan!
« Reply #23 on: January 18, 2019, 12:36:51 »
Interesting Naj,
Its a new release.
« Reply #24 on: January 19, 2019, 02:16:53 »
Your solenoid is almost certainly internally rusty.  I think I have a fix.  I yellow zinc plated mine and although I soaked it in oil it ended up stuck.  Horribly stuck.  After looking at the various options for dissasembly I didn’t like any of them. After staring at it for awhile I figured out a solution.  The center of the back side is brass.  I drilled a small hole of around 5mm just through the center of the back.  I then sprayed some oil in the hole and began hammering the shaft back and forth.  After I finally got it to move I started spinning and spraying until I had flushed all the rust from inside the solenoid.   Once I had it cleaned and lubed the way I wanted I tapped it to 6mm with a grease covered tap to avoid dropping any shavings into the solenoid.  Here is the tricky part. I put a little cyanoacrylate (crazy glue) on a 6mm brass bolt and threaded it in just deep enough to match the thickness of the back cover and no deeper or you will restrict shaft movement.  After the glue dried I cut it off and ground it flat with my dremel tool.  Almost undetectable repair.  Since your seems to be only maginally stuck you might only need a hole large enough to slip a plastic “straw” that attaches to your favorite spray can lubricant.  2-3mm.
« Last Edit: January 19, 2019, 08:22:13 by Shvegel »
