Author Topic: 25 amp stubby fuses  (Read 6647 times)
johnm
25 amp stubby fuses
« on: November 09, 2016, 13:41:30 »
 I just received word after ordering two -  25 amp fuses for my 1970 280SL from my local Mercedes dealership that Mercedes can no longer supply these. Seems strange to me. Would appreciate direction on how I may acquire these or alternatives others have used for these stubbier higher amperage fuses.
Thanks... John
Jordan
  • Canada, ON, Jordan
Re: 25 amp stubby fuses
« Reply #1 on: November 09, 2016, 15:01:51 »
John, Buds Benz sells the stubby as part of a kit of fuses.  Volvo also sells them http://www.cvi-automotive.se/en/articles/14432/6-fusebox but shipping could be costly unless you can find a closer supplier.  I'm sure others will step in with other suppliers.
I see authentic classics also carry it, but its not cheap here. http://www.authenticclassics.com/25A-Short-type-Fuse-for-Mercedes-p/auth-003741.htm
« Last Edit: November 09, 2016, 17:59:24 by Jordan »
Marcus
66 230SL  Euro 4 speed
kampala
  • USA, CA, Hermosa Beach
« Reply #2 on: November 09, 2016, 22:30:03 »
If originality INSIDE the fuse box is not of concern, you can very easily drill out the spacer where the stubby fits and use a full-size correct amperage fuse that will cost only pennies but more importantly, if you blow a fuse on the road, you will find something that will fit to get you going.
250sl - later - manual
280sl - 1971 - Auto - LSD
johnm
« Reply #4 on: November 10, 2016, 12:08:07 »
 This has been very helpful. Thanks very much...John
tom.hanson
« Reply #5 on: November 16, 2016, 23:09:31 »
I have them in stock.
