Author Topic: 123 ignition  (Read 6263 times)
StevenF
  • USA, NY, Merrick
123 ignition
« on: April 09, 2016, 01:11:36 »
I am interested in finding out about the 123 ignition.  I  just rebuilt my engine...should I get buy one?
Has anyone installed one ?
Feedback?
Pros? Cons?
Steven
1971 280sl
Red Metallic
Bamboo MB Tex
Larry & Norma
Re: 123 ignition
« Reply #1 on: April 09, 2016, 07:30:38 »
Yes, this is a great mod for smooth running and no more points adjusting.
Some controversy regarding whether to use a spring or not. See previous posts.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
450sl
Re: 123 ignition
« Reply #2 on: April 09, 2016, 14:08:16 »
I also use the 123  best you can buy ,i think.
Re: 123 ignition
« Reply #3 on: April 09, 2016, 15:09:46 »
There is also a detailed article about the 123 in Pagoda Notes, Volume 3 No 4. See sticky on General Disc forum. All back issues are available to full members in the technical manual section.
Re: 123 ignition
« Reply #4 on: April 09, 2016, 18:46:16 »
I installed one years ago and could tell the engine ran noticeably smoother on it. Have not heard but positive experiences from others either, so I recommend it.
Rolf-Dieter ✝︎
  • Canada, ON, London
Re: 123 ignition
« Reply #5 on: April 09, 2016, 19:29:57 »
Cees,
Did you purchase the kit and install it yourself ? I'm thinking of doing it.
Tyler S
  • USA, CA, Encinitas
Re: 123 ignition
« Reply #6 on: April 10, 2016, 00:53:16 »
Alfred (66andBlue) and I installed one in his 280. It is fairly straight foreward and definately within the realm of a DIY. It is just like installing any other distributer but the only tricky part is getting the distributer housing clocked in the correct location. After that its hook up the wires and set the timing at 3000 rpm with the total advance you want. Follow the directions to set the rotary dip switch for the proper advance curve programming. Make sure to remove the old thrust coil spring from the pedestal bore before installing the distributer, some have had accelerated wear in the 123 with leaving it in.
« Last Edit: April 10, 2016, 00:58:32 by Tyler S. »
Re: 123 ignition
« Reply #7 on: April 10, 2016, 06:39:23 »
Hi Rolf-Dieter, yes I got the kit from Van Dijk in Holland and installed it myself. Can't remember whether I left the spring in place so will have to check that one! With the instructions provided it was pretty straightforward plus there's a lot of information on this forum and in Pagoda Notes. Good luck,
Rolf-Dieter ✝︎
Re: 123 ignition
« Reply #8 on: April 10, 2016, 13:00:53 »
Thanks Tyler and Cees for the information. I will now use our search function for additional information.
Cheers,
Dieter
