Author Topic: 280sl cylinder head hole what is missing?  (Read 6068 times)
Autobob
« on: February 25, 2016, 20:28:34 »
Attached photo at red arrow, we have a threaded hole but do not know what goes there please advise, it is next to cylinder #6.
Arrgg, It would have been so much simpler if this car had been assembled when it arrived. So many missing parts...
Thank you, Bob
kampala
  • USA, CA, Hermosa Beach
Re: 280sl cylinder head hole what is missing?
« Reply #1 on: February 25, 2016, 22:38:31 »
I think that is the port for a Thermo Time Switch if your car is a late 280sl.  Earlier cars had this switch on a pod closer to spark plugs 2 & 3.  Later cars have this switch next to spark plug 6.  Sometimes, this port is used for a cooling by-pass modification and in such cases the TTS is moved into the bypass line.
250sl - later - manual
280sl - 1971 - Auto - LSD
Autobob
« Reply #2 on: February 25, 2016, 23:00:22 »
Thank you that helped, yes this is late model 1971, I found it in technical forum part 001 545 92 24. Looks like NLA from Benz, Joe or Alfred would you have one of these?
« Reply #3 on: February 25, 2016, 23:10:27 »
Thermo time switch? That should be readily available.
Autobob
« Reply #4 on: February 25, 2016, 23:13:12 »
OK then part number in technical may be superseded, will check that out. Thanks, Bob
« Reply #5 on: February 25, 2016, 23:31:21 »
Sorry, don't have one.
Autobob
« Reply #6 on: February 25, 2016, 23:54:46 »
@Benz DR, just heard back from MB dealer, TTS discontinued and no superseded number.  Rats.
Tyler S
  • USA, CA, Encinitas
« Reply #7 on: February 26, 2016, 02:12:22 »
Here is one at Auth Classics. Very Pricey
http://www.authenticclassics.com/Mercedes-Thermo-Time-Switch-fits-230SL-250SL-p/auth-004360.htm
Or you can use this one with a slight harness modification. The rubber boot will hide the connection.
http://www.authenticclassics.com/Mercedes-Thermo-Time-Switch-230SL-250SL-280SL-p/auth-006760.htm
« Reply #8 on: February 26, 2016, 05:51:36 »
Wow, crazy prices on these!
Tyler S
« Reply #9 on: February 26, 2016, 06:42:54 »
Another disappearing part that will go way up in price just like the fuel pumps last year.
WRe
« Reply #10 on: February 26, 2016, 07:18:30 »
here you find some info: www.sl113.org/wiki/Engine/ThermoTimeSwitch.
...WRe
