Author Topic: Radio Problems  (Read 4786 times)
  • USA, NC, Fuquay Varina
Radio Problems
« on: November 03, 2015, 19:54:30 »
Becker Radio sounds great with engine not running, with engine on very loud noise or buzzing noise.
Any help would be appreciated.
John Byrne
Re: Radio Problems
« Reply #1 on: November 04, 2015, 02:05:56 »
AM or FM?
Re: Radio Problems
« Reply #2 on: November 04, 2015, 03:27:24 »
Both AM and FM
WRe
Re: Radio Problems
« Reply #3 on: November 04, 2015, 08:15:51 »
you should check if your car (alternator, ignition coil, etc.) has appropriate anti-noise capacitors and correct ground straps. Alternatively or in addition to these elements you could install a noise filter behind your radio.
...WRe
Re: Radio Problems
« Reply #4 on: November 04, 2015, 15:34:55 »
Will do,
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
Re: Radio Problems
« Reply #5 on: November 04, 2015, 22:43:01 »
I'm having poor reception issues as well where signal comes and goes when driving.  I went so far as to purchase a new (old) becker (and I liberated one from an abandoned car) and will try some bench testing.   I was just wondering if it could be my antenna.    I always thought that FM was picked up by the radio itself but I get nothing unless I extend the radio and even then its marginal.
Has anyone found a marked difference by replacing their antenna.
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
Re: Radio Problems
« Reply #6 on: November 05, 2015, 16:16:43 »
To pick up FM signals the radio needs an antenna, either a built in one with amplifier (which old car radios did not have) or an external one that can be pulled out to the required length for best reception.
This post should explain it: http://www.sl113.org/forums/index.php?topic=13698.msg93011#msg93011
