Author Topic: Thinking out loud about valve guides  (Read 3809 times)
cruising
« on: September 21, 2015, 18:21:53 »
If my 1967 230 has had about 20 miles driven in 6 years wouldn't it make sense that the valve stems would be brittle/broken but the guides would be fine? I called the mechanic to get a quote to have valve stems seals replaced. He said I was wasting my time unless I checked the valve guides too (much more expensive). What do y'all think?
Re: Thinking out loud about valve guides
« Reply #1 on: September 21, 2015, 22:25:20 »
The valve guides can be checked during the relatively simple valve seal replacement. At such low useage you might as well just fit the new seals, they'll work for a few hundred miles even if the guides are worn.
twistedtree
  • USA, VT
« Reply #2 on: September 22, 2015, 00:52:00 »
I assume you mean the valve stem seals, right?  Is there some symptom that makes you think they are leaking?  Unless you are tearing down the head anyway, I wouldn't mess with them unless you are having a problem.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
« Reply #3 on: September 22, 2015, 15:15:54 »
Seems like an efficient use of time and resources.  ;)
