Author Topic: Alternator replacement suggestions  (Read 8237 times)
johnk
  • USA, OH, Avon
« on: April 20, 2015, 21:07:01 »
My alternator is not producing the minimum voltage so its time to replace it. My car is a 1968 280sl currently with a 35 Amp "Remy 13014" alternator. I read in past posts where some owners upgraded to 55 Amp alternators. I do not have AC now, but hope to some day. The alternator that AutohausAZ sells for my car is a rebuilt 35 amp Bosch (AL64x) for $75 while BudsBenz sells a 55 Amp B208-015m for $150 (does not name manufacturer)
Any suggestions or past experience with these? I like the idea of the higher amps, but I really don't want to start changing other parts to accommodate it.
John
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
TOMNISTUFF
  • Canada, Qc, Levis
Re: Alternator replacement suggestions
« Reply #1 on: April 20, 2015, 23:46:40 »
Hi John,
I just checked Rock Auto, where I bought my rebuilt one for a good price.  They are out of stock apparently.  Then I googled AL74X (X means rebuilt), and found several places in the U.S. that sell them rebuilt.  Summit Racing has them for $86.97 plus a $5 core charge.  AutohausAZ wants $85.50 plus $8 core charge.
Google (or similar are your best friends).
I can tell you where to get the connectors and how to wire it.
Good Luck.
Tom Kizer
Baybear
  • USA, VA, Midlothian
« Reply #2 on: April 21, 2015, 12:50:29 »
I used the Bosch AL 72X on my '71 which is 55amps and is direct plug and play, same housing and connectors and external regulator. I believe the 74X has internal regulator and requires wiring adaptors.
Will
« Last Edit: April 21, 2015, 12:57:52 by Baybear »
Will Milby
1970 300SEL 6.3, 1971 280SL, 1972 300SEL 4.5, 1972 Super Beetle, 1998 SL500, 2010 350 GLK, 2012 SLS AMG
TOMNISTUFF
  • Canada, Qc, Levis
« Reply #3 on: April 21, 2015, 14:23:43 »
The 55 amp AL74X can be either internal or external regulator.  Mine is external.  I replaced my fender-mounted original regulator with a more modern 280SL regulator that looks the same as the 230SL regulator.  I wanted the car to look pretty close to original.
The connectors on the AL74X are completely different than the original 35 amp alternator (which had no connectors originally, although the newer 35 amp alternator does have connectors, apparently).  Although the connectors on the AL74X are different than the old 35 amp alternator, the "CONNECTIONS" are the same - DF, D-, D+, B+ and Ground (frame to mtg. bracket).  It's just necessary to re-terminate the wires with two new connectors.
I don't remember how to rewire the harness for an internal regulator alternator.  I would have to study it again.
Tom Kizer
johnk
  • USA, OH, Avon
« Reply #4 on: April 21, 2015, 15:42:40 »
This is a big help. The picture of the al72x at advanced auto seems to have the same connections as mine.
thanks gents!
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
alchemist
  • USA, NY, GRAND ISLAND
« Reply #5 on: April 28, 2015, 01:34:05 »
I also bought an alternator from Advanced Auto for 67 230SL, it has the original fittings.
sgp
« Reply #6 on: October 14, 2017, 21:13:12 »
How difficult is it to replace the alternator? Do you know of any good link that tells you how to do it?
Cheers
sgp
Alternator Replacement
« Reply #7 on: October 14, 2017, 21:14:22 »
Does anyone know how to replace the alternator on a 250sl 1967? Any links and videos would be very helpful.
Cheers
