Poll
Should the downshift from 4 in deceleration engage to 3 or go to neutral
Not sure
1 (50%)
Always
1 (50%)
Total Members Voted: 0
Author Topic: 1969 280SL automatic transmission down shift  (Read 4678 times)
billeve
« on: July 14, 2013, 23:36:40 »
When decelerating my 1969 280SL goes from 4th to neutral at 38mph, is this normal?  At any speed between 15-38mph it will engage to 3rd if start to accelerate again. ???
Larry & Norma
Re: 1969 280SL automatic transmission down shift
« Reply #1 on: July 15, 2013, 07:56:45 »
Should never go to neutral unless you put it in neutral ???
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
« Reply #2 on: July 15, 2013, 16:36:40 »
When decelerating my 1969 280SL goes from 4th to neutral .....
Are you sure it goes into "neutral", or does your car have one of these fuel shut off switches that is activated upon decelaration?
« Reply #3 on: July 15, 2013, 20:54:22 »
Your poll cannot be answered with the options provided. Because the question itself lists two possible answers but the answers are not those two.
« Reply #4 on: July 16, 2013, 04:01:45 »
Make sure your fluid level is correct.  It should be between the marks when running in park, warmed up on perfectly level ground. The quanitity of fluid between the two marks in one pint !
