Author Topic: Questions regarding soft top  (Read 6899 times)
Pesherton
« on: March 03, 2013, 21:44:09 »
As far as i understand from the technical manual, my recent acquisition (230sl) has an original sonnenland soft top, replaced during restoration some years ago. But, the rear corner edges tend to lift slightly just as i have seen on many other cars during my search. Since the top is in very good overall condition, replacement feels somewhat over the top if you pardon the pun..
Is there any way to sort this out without replacing?
Re: Questions regarding soft top
« Reply #1 on: March 03, 2013, 22:12:14 »
There are lots of articles on this problem.  The main cause is how you put the top away into the soft top hutch.  If not careful the corners of the top get turned up and thus the problem.  Some use plastic to firstly ensure that it does not get damages as it is lowered but it also helps to turn the edges down once it is stored. Do a bit of a search and you will see several solutions.  With some time and effort the upturned corners can ge corrected.
Pesherton
« Reply #2 on: March 04, 2013, 11:19:33 »
Thanks Garry!
Tried searching for it before i posted, but it seems i have to do my homework a bit better ;)
« Reply #3 on: March 04, 2013, 12:18:59 »
Here is a couple to get you started.
http://www.sl113.org/forums/index.php?topic=9376.0
http://www.sl113.org/forums/index.php?topic=13468.0
http://www.sl113.org/forums/index.php?topic=8940.0
Just punch in soft top in the search frame under forums and see pages of softtop problems and fixes
Flyair
« Reply #4 on: March 04, 2013, 12:57:53 »
It looks as an excellent show & tell topic at the next Group meetings. The edges of my soft top are obviously curling up, so I would be very keen to get some practical advice and I suspect from seeing that the topic comes back regularly, many of us would join me in that exercise. The question remains whether the curling process is reversible, once the curls are there…?
« Last Edit: March 05, 2013, 12:52:11 by Flyair »
Stan
2011 SL550 AMG
2011 GL
2015 GLA
Pesherton
« Reply #5 on: March 05, 2013, 10:55:15 »
Very good explanations, many thanks!
« Reply #6 on: March 05, 2013, 18:46:47 »
Yes it's reversible, at least it turned out (pun again) to be in my car. In fact, I now have to moderate what I do because as a result of diligent 'tucking under' I was starting to have the opposite problem: the corners curling down instead of up!
Pesherton
« Reply #7 on: March 28, 2013, 13:53:35 »
Like Cees and others, i can now vouch for the fact that this cure works very well indeed  :D
Soft top is looking great again!
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
« Reply #8 on: March 30, 2013, 12:26:16 »
I must be missing the trick on the "tucking under" method. Once I stow the back edge of the soft top in the hutch, i can't get my fingers in there to tuck the edges under. What's the trick?
- 2024 Mercedes GLE 350
- 2024 AMG C43 Sedan
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
« Reply #9 on: April 01, 2013, 22:29:37 »
Figured out the tuck under method. Works great!
