Author Topic: HELP! Need Pistons for 230SL (001-5803)  (Read 3584 times)
Allen F
« on: July 07, 2004, 08:49:10 »
Hi Folks,
I am in desparate need of a piston for my 230SL.  We found 5 in the US, and need a sixth to complete the engine rebuild.  I need a part No. 001-5803 piston.  If anyone has a source for one of these, it would be greatly appreciated.
Allen Frechette
Re: HELP! Need Pistons for 230SL (001-5803)
« Reply #1 on: July 07, 2004, 09:37:44 »
What size is that?  There's standard, .50 mm and 1.00mm oversize. I have .50mm in stock. late 3 ring.
 There's 3 different types used on these cars. Early 4 ring, early 3 ring and late 3 ring pistons. The later pistons have a bigger pin hole and shorter skirts on the pistons.
The second version is all but impossible to find so you may have to change conecting rods if youi have that type and go to the late ones or early 4 ring with rods.
Daniel G Caron
« Reply #2 on: July 09, 2004, 04:05:10 »
try james at better cars, 14041 McGregor Blvd, Ft. Myers, Florida.
941-489-1565
Best of luck
Pagoda Red
red kelly
« Reply #3 on: July 09, 2004, 20:09:05 »
Talk with Dan Caron.  If he can't come up with your parts, then refer to this Group's vendor list at:
« Last Edit: July 09, 2004, 20:09:46 by rwmastel »
