Author Topic: Spark plug wires - which set to buy  (Read 5260 times)
marios
« on: March 22, 2012, 05:34:33 »
I need to replace all of the wires and was wondering which one you guys would recommend I get and where to get it.
Appreciate the feedback.
Mario
franjo_66
  • Australia, NSW, Point Piper
Re: Spark plug wires - which set to buy
« Reply #1 on: March 22, 2012, 08:38:13 »
Hi Mario
I think that the type of ignition system (eg original, transistorized, aftermarket electronic, etc) as well as year of your car comes into play when choosing the right leads.
I have just fitted an aftermarket 123 distributor together with a Bosch hi-energy red coil on my 1965 230SL. I used the OEM style leads made by Karyln. These have copper cores with Bakelite ends and no resistors.
If you do a forum search on "spark leads" you will get quite a bit of information.
Franjo
Franjo
1965 230SL Black/Auto/RHD
2005 Porsche Cayenne Turbo
1983 BMW 735i
1986 560 SEC
1991 500SL
1982 Holden Statesman DeVille
marios
« Reply #2 on: March 22, 2012, 16:01:49 »
Thank you. I found the part in auto haus az
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #3 on: March 22, 2012, 19:50:40 »
Mario,
I just bought my complete set here in San Marcos.  Just drive up there and pick them up.  You are on 5-8 miles away :)
http://kingsborne.com/
Talk to Kris.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Jordan
  • Canada, ON, Jordan
« Reply #4 on: March 22, 2012, 20:15:13 »
Kris, I don't know if Kingsborne have the correct plugs listed for the 230SL as the engine they list is incorrect.
Marcus
66 230SL  Euro 4 speed
mrfatboy
    • Mrfatboy
« Reply #5 on: March 22, 2012, 20:45:43 »
They didn't have the correct complete set for the 280sl.  They custom made them for me on the spot.  I just brought in my old plugs and they matched to length.
They used the VESO 105 distributor connector and I believe the ZLE 130 connector (which is not on the website)which is a little longer.  I think it's supposed to be the ZLE 120 but they don't have those.
http://www.beruparts.com/product.sc?productId=227&categoryId=12
I don't know the differences if any between the 280 and 230 plug set.
« Last Edit: March 23, 2012, 01:14:49 by mrfatboy »
Signal Red
4 Speed
« Reply #6 on: March 23, 2012, 00:50:49 »
.... I don't know the differences if any between the 280 and 230 plug set. ...
It is all described here: http://www.sl113.org/forums/index.php?topic=12919.msg87587#msg87587
The main difference is on the distributor end.
280SL connectors are bent 90 degree - just like your VESO 105 (0 300 513 105) -{I believe you mistyped when you wrote VES 105}- whereas 230SL connectors should be straight up connectors.  The current WVES 1 (0 300 413 101) BERU connector might be suitable for a 230SL distributor connector since it has a wood screw for the 7mm diameter cable connection.
On the spark plug end the (almost) original connector was a ZLE 120 (0 300 062 101) - it was about 25 mm shorter (total length 103 mm) than the ZLE 130 (total length 128 mm) that you got.
« Last Edit: March 23, 2012, 01:05:28 by 66andBlue »
marios
« Reply #7 on: March 24, 2012, 16:42:09 »
Thanks for the feedback guys! Everyone here is so helpful.
Thanks!!
