Author Topic: Haynes Manual  (Read 3936 times)
Larry & Norma
Haynes Manual
« on: February 20, 2012, 10:35:15 »
My Haynes manual is titled 'Mercedes Benz 250 & 280'
I have seen one on the internet titled 'Mercedes Benz 230,250 & 280'
Is there different content in these?
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
W113SL
Re: Haynes Manual
« Reply #1 on: February 20, 2012, 15:02:04 »
They are one and the same.  Correct title is Mercedes-Benz 230,250 and 280
Re: Haynes Manual
« Reply #2 on: February 20, 2012, 15:56:01 »
One of the claims of the Haynes Manuals is that they start with a car, and take it apart to learn how to do things.  "Every manual based on a complete teardown and rebuild" is their claim, right on the cover.  The Haynes Manual I have is titled "Mercedes-Benz 230, 250 & 280  1968 thru 1972, 6-cylinder sohc Sedan Coupe Roadster"    ISBN 0 85696 346 1.  Though there is an SL (113) on the cover, other cars are covered including ones with carburetors.
I've always found some of these manuals rather humorous and a bit lacking...for example, this past summer, upon recommendation of Joe Alexander, I changed my water pump.  There is a brief mention of removing the radiator, and the section on that doesn't begin to cover the myriad other things one must do, and how to do them, in order to remove the radiator.  It makes almost no mention at all of removing the fan clutch, which was arguably the most time consuming part of the task, and makes no mention of the short and long versions of the pump.  There is, however, a section on "overhauling" the water pump, which is something most people do simply by replacing.  Heck there isn't even a core charge on the water pump so even the manufacturers don't "overhaul" them.
But, I sure love their cut away drawings on the front cover!  ;)
Larry & Norma
Re: Haynes Manual
« Reply #3 on: February 20, 2012, 16:15:21 »
Yes I thought it might be one in the same. These early manuals were not very thorough as you say Michael.
2023 Ioniq6
2005 C230
TOMNISTUFF
  • Canada, Qc, Levis
Re: Haynes Manual
« Reply #4 on: February 20, 2012, 16:32:36 »
I agree with everything that's been said.  I supplement the Haynes manual with the Chilton's repair and tune-up guide which covers lots of cars from 1959 to 1970, as well as the BBB, which is also not complete.  By studying all three before starting, it's not too bad.  The Chilton manual by itself is very confusing to me, but as a supplement, it's worth having.  I personally think that the Haynes line drawings are easier to understand than the Chlton"s underexposed photos.
I would love to have a flag size poster of the Haynes Pagoda cutaway on my garage wall.
Any way you figure it, we're lucky to have these books.  Old cars of other makes seem to be very poorly documented when compared to Mercedes cars.
The sl113.org Technical Manual might eventually be the ultimate Pagoda manual if we all work diligently.  It's already got a really good start, thanks to all you guys.  Pagoda Notes is no slouch either.
Tom Kizer
