Author Topic: Need a (early) Fuel pump and a fuel level sender  (Read 4159 times)
BarryD
« on: November 29, 2011, 04:51:31 »
This weekend I found that my fuel pump is seized. And when I handled the fuel level sender just disintegrated into a pile of wires and broken contacts. I'm guessing that the pump is gummed up and it wouldn't make sense to hit it with 24V momentarily - especially if it's rebuildable.
Does anyone know of someone who may rebuild the pump? Or know where I can get a replacement for less than $695.00 and $56 for the bracket? Similarly is it possible to get a fuel level sender for less than $241.00? This was an expensive weekend!
Re: Need a (early) Fuel pump and a fuel level sender
« Reply #1 on: November 29, 2011, 10:21:05 »
Do check the Fuel section in the Technical Manual. It has detailed info on rebuilding Fuel pumps...
George Des
« Reply #2 on: November 29, 2011, 13:39:16 »
Do as Peter says--see the Tech Manual. Do not hit it with 24 volts. If you do, it will not be rebuildable!
George Des
« Reply #3 on: November 29, 2011, 16:03:07 »
By ' early sender ' do you mean the one that has the float on the end of the arm?
BarryD
« Reply #4 on: December 05, 2011, 00:14:25 »
No, the sender is cylindrical with a float which moves vertically located inside an aluminum (I think) tube. By early, I meant that the fuel pump is the tall one.
This weekend I took the bottom off the fuel pump and cleaned everything inside. Then I polished with wet or dry sandpaper. I carefully took the top off the motor and noticed no fuel leakage. Then the pump worked! we'll see how long it lasts.
I was getting ready to finally start the car and I found the injector pump oil sump is completely empty.
