Author Topic: Extra fuse for left high beam  (Read 6760 times)
twistedtree
  • USA, VT
« on: April 14, 2010, 22:34:48 »
I was having trouble getting the left high beam working on my '70 280SL and finally discovered a small, secondary fuse box mounted by the clutch fluid reservoir.  It doesn't show up on any of the wiring diagrams that I have.  It holds two fuses, but only one has wires going to it, and sure enough it was blown.  I replaced it the lights started working.
What gives with this extra fuse box?  It appears to service nothing but the left high beam and seems redundant with fuse #10 in the main box.
And that leads me to another issue.  The high beam flasher doesn't work either.  According to the wiring diagram, it goes directly from Fuse #1, to the steering column stalk, then to fuse #10.  I have power at fuse #1, but nothing at fuse #10.
Before I start pulling apart connectors on the steering column, are there any more undocumented fuses that I should be aware of?  In other cars, the stalk operates a relay, not the light directly, but that doesn't appear to be the case wiht teh W113?
Thanks, as always,
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
dtuttle123
Re: Extra fuse for left high beam
« Reply #1 on: April 14, 2010, 22:54:25 »
Hi Peter - If it's the same fuse box that I'm thing about - the auxiliary two fuse box was used for a couple of things - the radio, and the power antenna.  I think I've heard that fog lights could be wired through there.
 I don't know about the left high beam - that doesn't sound right - that's #10.
Attached is the fuse description from my 250SL - may be different for the 280SL.
twistedtree
  • USA, VT
« Reply #2 on: April 14, 2010, 23:39:23 »
The fuse designations are the same on the 280, at least for the headlights.   As best I can tell, the wire is supposed to go directly from fuse #10 to the left high beam, but actually runs through this aux fuse box.  Maybe a previous owner hacked things for some reason.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
« Reply #3 on: April 15, 2010, 00:22:28 »
If you are asking about the highbeam flasher that is part of the multi-function column switch, this function was disabled on USA version cars. Can be restored by following the steps in the Tech Manual.
Richard M, NYC
twistedtree
  • USA, VT
« Reply #4 on: April 16, 2010, 01:03:44 »
Yes, that's what I'm talking about.  Many thanks for the pointer - you saved me a ton of time.  I missed that part of the tech manual and will see if I can restore the function.
Other than seized wiper spindles and a front end rebuild, I think I'm ready for state inspection.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
xcashewx
« Reply #5 on: April 16, 2010, 02:12:26 »
i restored the flash function on my car as well. took ten minutes. just locate the disconnected wire which will be taped, and re connect it. easy as that
« Reply #6 on: April 16, 2010, 04:07:45 »
reconnect to what, exactly?
« Reply #7 on: April 16, 2010, 15:12:14 »
