Author Topic: csv on 1965 230sl  (Read 4890 times)
markh
csv on 1965 230sl
« on: May 19, 2009, 12:07:20 »
checked out csv and found it not spraying fuel removed from car and after examining valve found the black rubber insert all swallen and split i am in england could anyone tell me if there is a repair kit for these or anyone that recon them many thanks   mark
Re: csv on 1965 230sl
« Reply #1 on: May 19, 2009, 13:19:47 »
Hello, Mark,
There is a small 'O' ring between the solenoid and needle valve and a bigger 'O' ring between the valve assembly and inlet manifold. Are you talking about one of these?
They are available separately from MB.
markh
« Reply #2 on: May 19, 2009, 14:24:51 »
hi no its not the o rings  i have removed the solenoid off the csv and there is a rubber insert about 1 cm long which is pushed in the valve have called mb here and there saying no repair kit so what now   regards mark h
« Reply #3 on: May 19, 2009, 14:31:38 »
Hello, Mark,
Besides the 2 O rings, there are no other rubber parts in the csv.
Have a look in the wiki:
http://www.sl113.org/wiki/Engine/ColdStartValve
markh
« Reply #4 on: May 19, 2009, 15:36:26 »
hi naj just looked at csv tec sheet and it does not show this insert but honest i have taken thie rubber sleeve out it sits where the small o ring should be but fits down the hole where solenoid needle lives confused i am   regards marh
« Reply #5 on: May 19, 2009, 18:19:28 »
Maybe the PO did a mod  ???
