W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: bpossel on January 07, 2008, 04:50:16
Title: Powder Coat Overflow Tank?
Post by: bpossel on January 07, 2008, 04:50:16
Hello!
Has anyone powder coated their brass overflow tank?
From what I understand, the brass tanks are 3 pieces soldiered together.  The powder coat process requires heating the painted surface, so am concerned that the heat may melt the soldier.
Anyone have any direct experience with this?
 :) Thanks!
Title: Re: Powder Coat Overflow Tank?
Post by: DavidBrough on January 07, 2008, 06:41:49
Hi Bob,
I’ve had my header tank powder coated and when I took it in I do remember a discussion about soldered or brazed joints. If I remember rightly there was a trial process to check suitability and I think it was decided that the joints were brazed. In the end I went ahead with no problems. He did say if it had been soldered it would have just fallen apart in the coating process. I had this done about 2 years and 10,000 miles ago and no leaks. Hope that helps.
David Brough
1969 280Sl Auto with A/C
Post by: bpossel on January 07, 2008, 07:13:37
Hi David,
Thanks for your reply and direct experience!  I guess it would make sense...brass being brazed....
I will also let this group know how mine turns out.  I currently have it at the powder coaters.....
Post by: 114015 on January 15, 2008, 15:17:04
Hello colleagues,
Yes, I have "learned" the same.
My 230 overflow tank is mostly soldered and was "test-baked" at 200 °C before possible coating; it came apart. Thus, my tank could not be powder-coated ...
(Magdeburg, Germany)
