W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Charles 230SL on September 19, 2022, 18:02:10
hello all, can someone please explain the purpose of this bolt on the side of the block? (red arrow in the photo below) Reason I ask, the bolt was missing when I got my block back and I'm not sure what it looks like nor how long it is. thanks in advance, charles
Nothing goes there. I don't think the hole is even threaded.
Oh good grief, I pointed the arrow at the wrong thing! Thanks Joe, do you know what the bolt further below on the chain gallery is for?
It is a rounded end bolt that helps to keep the chain from jumping off. On a power steering car it also holds the lower steering pump reservoir bracket. There are two length bolts depending on if it has power steering or not.
Pat is exactly correct.
Pat and Joe - thank you ;) !
As future reference for anyone needing a picture and length of the bolt, here's a link providing additional information: https://www.sl113.org/forums/index.php?topic=27136.
