W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: lreppond on August 26, 2022, 16:18:19
I’m going to be replacing my warn decals on speed relays with new reproduction ones. I know the proper placement or orientation but I’m not sure how I should remove the old adhesive that’s literally bounded to the tops. I was thinking about using denatured alcohol but I don’t want to damage the relays. Any advice? Goo gone? Orange oil? Etc.
I have used goo gone (or similar) with good results. Be sure to clean that off with some light solvent. If you put the stuff on a clean cloth that avoids the potential for an "oops" of liquid on the relay.
Peel, then WD-40
3M Prep-Sol, none better.
I had both GooGone and WD-40 in my garage. I started out with just a little spray of WD-40 on a microfiber cloth. It took a little time to soften the adhesive but once it did it came off with not much effort (rubbing). After it completely evaporated, I wiped it down with 90% IPA. As an added bonus, it left the plastic shell of the replay looking new.
Unfortunately, I looked up 3M PrepSol and it’s unavailable in California even though it’s water based and low VOC! Shouldn’t surprise me!
Thanks gentlemen for your suggestions.
Len,
I'm very fond of a good IPA, and have even brewed a few decent ones myself, but using one in this way is a new idea to me! ;D
-David
I have used a 3M product in a spray can that is quite good, gentle on paint surfaces and available here in CA:
https://www.amazon.com/3M-03618-Adhesive-Remover-oz/dp/B000BQYA7W
i just replaced mine. I just pealed them off and used Eastwood pre clean. You could also just rube it off with goof off or other solvent.
