W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: JohnnyC on June 29, 2022, 01:44:12
Greetings,
I am in process of a rear axle rebuild and I can't find information about the fit of the sleeves (Figure 35-5/5, items 11a and 11b, BBB) on the connecting bolt, item 7. When I disassembled the assembly, the sleeves were not a press fit, and with very light force I was able to slide them off the connecting bolt. I now have new sleeves and they slide on the connecting bolt very nicely (after cleaning of course.)
I am concerned that the sleeves should be an interference fit onto the connecting bolt at their specific location to mate-up to the right axle half yoke brass bushings, which I plan on replacing. I am thinking the manufacturing tolerance was made too large for an interference if required. Picture attached.
Thank you all for this forum.
Cheers and God Bless,
John C.
They should just slide on to the shaft. Oddly, even though they're hardened and turn in brass bushings, they will often show a lot more wear than the softer bushings after years of use. Maybe someone can explain this.
Thank you Benz Dr.
It is a strange set-up. The sleeves that I removed did have wear on them (chrome removal) from the brass-grooved bushings on the yoke. What is interesting to me is the sleeves did not wear-down the connecting bolt surface without an interference fit. Perhaps they are loaded in such a way that does not permit the sleeves to rotate on the bolt (sleeves/washers stack-up). Being that I removed them without much force, I believe you are correct, as I agree also.
Cheers and thank you,
JohnnyC
If there is hard dirt etc that imbeds itself in the brass it will wear the harder metal away instead of wearing the softer metal. That could be the cause.
I have a cast iron plate I imbed diamond dust on it and hone carbide bits. The cast iron remains relatively unchanged.
Thank you, Kevkeller.
I understand what you're saying. Never thought of it like that, makes sense to me. I'll change-out the brass bushings also, and ream if needed. I'll post pictures later of the individual sleeves and bushings.
John C.
