W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Jagoffizier on May 20, 2022, 19:57:15
The bearings on my original fan clutch are starting to go, so I plan to replace it soon. I would appreciate guidance on which aftermarket unit to install, as units no longer available from MB Classic.
I just completed this job on my 250 SL. I did find the Behr clutch (OEM) and it was about $1000! I opted to continue looking. The folks around here were pretty well down on the URO unit. I found a Meyle from K&K out of Michigan and that is what I went with.
I did speak with my mechanic and he has been using Hudson.
Thank you for your answer. I also want to avoid $1000, but don't want to be too cheap either.
here I can find cheap ones only: https://www.daparto.de/Kuehlerluefter-Kupplung/Mercedes-Benz-SL-Pagode-W113/3-9310a012-851. Maybe the Meyle would be fine.
...WRe
Thank you for the reference.
Just replaced mine, given that I'm making every effort to retain OE on every part, was able to dig up a OEM MB part for $800.00
Thank you. I found a slightly used example and will have it installed next month!
